How to use for-loop inside a function
How to use for-loop inside a function - Can't figure out the syntax - Messaggi
#1 Pubblicato: 19/03/2018 07:11:17
similae
similae
0 apprezzamenti in 5 post.
I'm trying to make a function return a value from a matrix by running a small for-loop inside the function. How should I write it? Couldn't find examples how to use it.
#2 Pubblicato: 19/03/2018 07:49:55
Brian Runagle
Brian Runagle
13 apprezzamenti in 27 post.
Hi Mikko
The loop syntax needs tweaking, and the output variable needs to be defined. The attached file works for me.
kertoimetTest.sm (4,72 KiB) scaricato 1339 volta(e).
Hope this helps.
Brian
similae 19/03/2018 08:29:00, Davide Carpi 19/03/2018 10:25:00
#3 Pubblicato: 19/03/2018 08:29:34
similae
similae
Thank you!!!
Mikko
#4 Pubblicato: 19/03/2018 09:53:50
Nicolae Olaru
Nicolae Olaru
1 apprezzamenti in 115 post.
Greetings
I have not been able to understand the purpose for which the imagined algorithm is used. As the question arises, it is a case of express identification of a certain value in the "kertoimet" matrix. In this case in 99.99 (9 ...) of cases, the result will be an error. If so then you can avoid ambiguity using the first procedure (case identification) in the attached file. Looking at the problem in terms of practical use, in the first column of the "kertoimet" matrix there are some non-dimensional coefficients corresponding to circular x-ray surfaces with the area expressed in square millimeters. In this case, a linear interpolation of these coefficients would be useful depending on the radius of the circle, and the procedure is the one presented in the case of interpolation.
Imagination.sm (6,22 KiB) scaricato 1241 volta(e).
#5 Pubblicato: 19/03/2018 18:16:29
... sorry: I understand nothing in there. Too few information.
Yes, you can best fit a circle from few points [not done in Smath]
