AYUDA SMATH STUDIO
AYUDA SMATH STUDIO - EMPTY MEETING SPREADSHEET - Messaggi
#1 Pubblicato: 19/08/2025 02:39:17
Giomar Leon Gutierrez
0 apprezzamenti in 7 post.
I WAS WORKING ON A SPREADSHEET WHEN SUDDENLY I GOT AN ERROR MESSAGE AND CLOSE THE SHEET. WHEN I OPEN THE SHEET AGAIN I FIND IT EMPTY AND I GOT A MESSAGE "Object reference not set to an instance of an object" HELP PLEASE. ENVIO MI HOJA DE CALCULO.Diseño a corte.sm (1,27 MiB) scaricato 1593 volta(e).
Modificato 19/08/2025 22:32:42
#2 Pubblicato: 19/08/2025 17:09:56
Gruppo: Moderator
The file loads without issues for me.
With SMath closed, you can try to open the %appdata% folder (write it in the windows address bar and hit enter) and then rename the SMath folder to something else (f.e. SMath_old), then launch the worksheet again and load the required extensions. If nothing changes you can revert everything by deleting the new SMath folder and renaming the old folder to its original name
