Symbolic resolution from mathcad to SMath-Studio
Symbolic resolution from mathcad to SMath-Studio - symbolic resolution from mathcad to SMath-Studio - Messaggi
#1 Pubblicato: 31/08/2021 16:23:02
Erick Valentino
Erick Valentino
7 apprezzamenti in 29 post.
How can I do a symbolic resolution in SMath-Studio?
In mathcad there are: simplify, expand, substitute, etc.
When I solve an equation, I have to use "maple". Can this be done without using it?
Mathcad to SMath Studio.sm (103,48 KiB) scaricato 1359 volta(e).
#2 Pubblicato: 31/08/2021 16:52:14
Arie
Arie
94 apprezzamenti in 285 post.
The built in symbolic engine in SMath leaves much to be desired.
I know the maple plugin has at least some of the functionality you're looking for. Also you'll want to check out the Maxima plugin as that's very useful for solving symbolic equations as well.
#3 Pubblicato: 31/08/2021 19:34:42
Hi Valentino. This is a way.
Mathcad to SMath Studio.sm (102,93 KiB) scaricato 1443 volta(e).
Erick Valentino 31/08/2021 20:32:00
#4 Pubblicato: 31/08/2021 20:00:34
In Mathcad there are: simplify, expand, substitute, etc.
Most Mathcad command line work as well in Smath.
ODE Maple Example Copy.sm (118,52 KiB) scaricato 1334 volta(e).
#5 Pubblicato: 01/09/2021 09:16:33
... augmented version.
ODE Maple Example Copy.sm (134,42 KiB) scaricato 1375 volta(e).
#6 Pubblicato: 01/09/2021 16:40:43
Gruppo: Moderator
Maple and Maxima plugins has symbolic simplify functions.
Unfortunately SMath don't have this features natively.
#7 Pubblicato: 01/09/2021 18:36:42
Which of these 6 styles do you prefer ?
Mathematica has a long discours on that .
#8 Pubblicato: 01/09/2021 19:01:18
Gruppo: Moderator
You can write your own functions to make expand(),simplify() work as if they are implemented.
Don't sure if they will work with complicated function, but they are fine with simple ones.
#9 Pubblicato: 01/09/2021 20:05:05
Erick Valentino
Erick Valentino
Alvaro thank you very much, your solution has worked very well for me. I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement?
#10 Pubblicato: 01/09/2021 20:09:47
Erick Valentino
Erick Valentino
Jean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Conver" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for?
#11 Pubblicato: 01/09/2021 20:18:08
Erick Valentino
Erick Valentino
How did you put so many "boolean equals" without the parentheses being uncertain?
¿Cómo pusiste tantos "iguales booleanos" sin que los paréntesis sean inciertos?
Thank you
#12 Pubblicato: 01/09/2021 20:59:49
From an old Mathcad/Mathsoft contest.
#13 Pubblicato: 01/09/2021 21:05:48
Jean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Convert" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for ?
They just make the demand produce/solve.
Few more attached as you may need eventually.
Cheers Valentino ... Jean
Symbolic Convert Parfrac Primary FNCTS.sm (118,96 KiB) scaricato 1347 volta(e).
#14 Pubblicato: 01/09/2021 21:36:51
...I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; ...
Opt = Symbolic or Opt = None means that you must to right click over an expression, and choose Optimization / Symbolic or None, not a command.
About collect and other expression they aren't from SMath, but from Maple plugin, which is Maple version 6. So, you must to learn something about it. Maplesoft online help could be very extended: Maple help but you can also read some good manuals like "Aprenda Maple 8 como si estuviera en primero" from Universidad de Navarra (you can google it, it's free). Just a notice: Maple V have several differences about how handle strings and some other things, so if you can't find a good short manual about Maple 6 try only up versions.
#15 Pubblicato: 01/09/2021 21:45:04
With some hard work you can hack the SMath syntax: From https://en.smath.com/forum/yaf_postsm56111_Some-future-requests.aspx#post56111
HackingEqual.sm (3,3 KiB) scaricato 1888 volta(e).
overlord 02/09/2021 11:23:00
#16 Pubblicato: 01/09/2021 21:48:40
The continued fractions are not futile ... Explain.
Before the modern CAS, the main frame IBM, used continued fractions.
As well as the J_Fraction... Where is my Mathcad on that ?
Since then, the Padé normalized fractions have replaced
the continued fractions, more stable numerically, faster parallel.
#17 Pubblicato: 01/09/2021 22:12:27
... Expand options
#18 Pubblicato: 01/09/2021 22:21:44
... matter of preference.
Expand.sm (13,12 KiB) scaricato 1384 volta(e).
#19 Pubblicato: 02/09/2021 09:03:30
... more for your bed time reading, Valentino !
Smath is not envious of PTC_Mathcad ... Jean.
Inst_TurboGen Smath [SHORT].sm (19,63 KiB) scaricato 1109 volta(e).
Inst_TurboGen Signum.sm (86,11 KiB) scaricato 1286 volta(e).
Inst_TurboGen Smath.sm (118,82 KiB) scaricato 1296 volta(e).
#20 Pubblicato: 02/09/2021 11:24:40
Gruppo: Moderator
With some hard work you can hack the SMath syntax.
This is nice. I didn't know it could be done.
Formulas work even after brackets removed.
Not just a cosmetic removal.
Thanks a lot.
