Recursion
Recursion - Messaggi
#1 Pubblicato: 29/03/2016 13:05:05
Gruppo: Super Administrator
Three simple examples of recursion usage taken from this document: http://twt.mpei.ac.ru/ochkov/Recursion.pdf (created by V.F. Ochkov).
recursionExamples.sm (16,36 KiB) scaricato 1523 volta(e).
Alexander O. Melnik 29/03/2016 13:45:00, Davide Carpi 29/03/2016 18:13:00
#2 Pubblicato: 29/03/2016 13:09:10
Regarding 3-rd example: solution can be tested here: http://www.softschools.com/games/logic_games/tower_of_hanoi/
Regarding 2-nd example: as I mentioned, I took this example from the document, created by V.Ochkov. But I did a significant change against to the source - I've used vectorize function. Please see screenshot from referenced PDF:
What I don't understand, is why Mathcad gives correct result after call Fibonacci function with vector passed as an argument? How it determines that user wants this function to be called for every single vector element? Miracle!
Davide Carpi 29/03/2016 18:14:00
#3 Pubblicato: 29/03/2016 13:44:43
Gruppo: Moderator
Hello Andrey,
Thank you for your recent elevated activity on SMath
It is not a miracle. If you use an interval variable in Mathcad (n in this example is an interval variable - not a vector) then if you use a function and pass that interval variable to it, you will have the result of every element in that interval variable (Fibonacci(n)= ). There is a restriction here though. You can call that function, but you can not assign its result to a variable.
P.S. V.Ochkov is one of the person who knows quite a lot about Mathcad and Mathcad Prime
Andrey Ivashov 29/03/2016 14:08:00, Davide Carpi 29/03/2016 18:13:00
#4 Pubblicato: 29/03/2016 18:10:39
What you are saying Radovan is true, but NOT exactly: explain the nuance.
In Mathcad n:=1..5 is a "scalar vector". It will tabulate w/o rows
identification. It will not transpose as it does not exist as numbers,
just a "vanishing iterator" working when invoked.
Don't know how it is implemented in the Mathcad version Andrey is talking
about. Presumably it has Fibonacci built-in "Fibonacci(n)". It may have
two built-in algo: one giving Fibonacci(12)=144 ,,, and another one or the
same built-in around "IfIsArray". So, if given Fibonacci(12)=144
and for n:=1..12 it will run over each values of n=0,1,2,3....
thus tabulating Fibonacci(for each n)=1,1,2,3,5,8,13 ...
Fibonacci has a non-recursive form, something like pi from Simon Plouffe.
Pi [Simon Plouffe].sm (7,9 KiB) scaricato 1278 volta(e).
Davide Carpi 29/03/2016 18:14:00, Andrey Ivashov 30/03/2016 05:54:00
#5 Pubblicato: 29/03/2016 19:01:58
Hello Andrey,
If you ever meet Valery F. Ochov, his "colleagues" Konstantin, Viktor...
They helped me a lot in Mathsoft Collab and wish to thank them for Eternity.
My small brain is telling me the Mathcad "Vectorise Operator" is a creation
from the main inventors, mostly Allan Razdow. Generally, we can visualise
how it works under the hood like vectorising icfft(fft) ....
The code is deeper than reasonning. Vectorise over an RGB image will explode
the 3 R,G,B components side by side.
#6 Pubblicato: 29/03/2016 19:14:32
Radovan,
Thank you! Now I see... it is just another type of data.
Jean,
Thank you for clarifications and example!
#7 Pubblicato: 30/03/2016 01:28:23
Yes Andrey: just a scalar vector, abusely used in Mathcad ,
mostly for quick plot and gone wth the wind, like butter in the pan.
#8 Pubblicato: 31/03/2016 00:46:01
Mike Kaganski
Mike Kaganski
184 apprezzamenti in 434 post.
Two things I want to note:
  1. Over time, recursion has changed in SMath: in the past, it was possible to use recursion directly; currently it seems to require a programming function like line(), otherwise it reports "function not defined" error.
  2. Recursion isn't safe; improper termination condition that leads to infinite recursion will crash SMath. Try f(x):line(f(x),1,1) followed by f(2): (just remember to save your work first).
The latter indicates stack overflow, and absence of recursion depth checking. I hope that SMath will eventually implement a means of stack overflow protection, so that in such cases it will simply report "cannot evaluate: nesting too deep" instead of crash.
Also, it would be great if Andrey considered a kind of tail recursion optimization in the future.
С уважением, Михаил Каганский
frapuano 31/03/2016 04:12:00, Davide Carpi 31/03/2016 14:13:00
#9 Pubblicato: 24/06/2021 20:45:38
Hi. A way to handle recursions.
recursion.sm (85,22 KiB) scaricato 1459 volta(e).
recursion.pdf (330,55 KiB) scaricato 977 volta(e).
sergio 25/06/2021 05:08:00, Fridel Selitsky 25/06/2021 08:06:00
#10 Pubblicato: 25/06/2021 09:28:19
Recursion comes in many ways ... some attached.
1. Pure maths [Fibonacci, Factorial, Powers ...]
2. Curiosity [Hofstadter sequence]
3. Engineering application [Process Control Instrumentation]
4. Generate vector of functions [ChebyShev ...]
Jean.
PolyOrtho ChebyShev.sm (20,65 KiB) scaricato 1429 volta(e).
Maths Sequence Hofstadter.sm (33,26 KiB) scaricato 1489 volta(e).
Maths Fibonnaci.sm (71,28 KiB) scaricato 1471 volta(e).
#11 Pubblicato: 25/06/2021 10:45:03
Few more productive advanced applications.
Inst_Control ON_OFF.sm (21,23 KiB) scaricato 1441 volta(e).
Inst_PID Discrete Schema EXAMPLE_3.sm (22,94 KiB) scaricato 1507 volta(e).
Inst_PID Discrete Schema EXAMPLE_7.sm (28,75 KiB) scaricato 1474 volta(e).
Inst_PID Discrete Schema EXAMPLE_2.sm (28,09 KiB) scaricato 1481 volta(e).
Inst_PID Discrete Schema EXAMPLE_6.sm (30,3 KiB) scaricato 1491 volta(e).
Inst_PID Discrete Schema EXAMPLE_1.sm (32,01 KiB) scaricato 1496 volta(e).
