Forum SMath SMath Studio Bugs & Problems pdf plugin export filename 1 pagine (2 elementi) pdf plugin export filename - After doing a pdf export, the filename becomes xxx.pdf, not xxx.sm - Messaggi Vai all'ultimo post #1 Pubblicato: 09/12/2014 04:14:44 crun2 0 apprezzamenti in 10 post. Gruppo: User After doing a pdf export, the filename displayed on the title bar becomes xxx.pdf, not xxx.sm.When you close SM it is unable to save the sm file, until I saveas SM again. #2 Pubblicato: 09/12/2014 08:42:11 brotjob 7 apprezzamenti in 71 post. Gruppo: User I can confirm this. I opened a issue in the issue tracker: Unable to safe after pdf export 1 pagine (2 elementi) Nuovi post Nessun nuovo post
