1 pagine (5 elementi)
Specified Unit crash in 0.93 - Messaggi
I have found that in versions 0.92 and 0.93 there is a problem with specifying units for an answer.
In 0.91 it would simply show that there was a syntax error by borering the specific block RED.
The error is when multiple units are combined to for other units for example torque
(Nm) or acceleration (m/s^2). If one of the fieldsis left blank then 0.92 and 0.93 crash.
in 0.91
1*'N*1*'m=#@'N*
in 0.93
1*'N*1*'m=#@'N*
1*'N*'m=#@#*#
I know this seems like a small problem, but it causes me huge pain when do long calculations and lots of work is lost due to a typo!
It appears that a # may not be generateing in the code to indicate a no value entity.
Thanks for the help
in 0.91
in 0.93
1*'N*'m=#@#*#
Thanks for the help
Sorry should read
in 0.91
in 0.93
Thanks for the help
in 0.91
1*'N*1*'m=#@'N*
in 0.93
1*'N*1*'m=#@'N*
1*'N*'m=#@#*#
Thanks for the help
I did not understand quite well, sorry - but I think I can reproduce the crash.
See the picture please:
When you just type in the rightmost placeholder (used for changing units), say *N and press enter, the crash occurred. This is a typo, but should not be causing a crash.
Thanks Radovan,
Sorry for the bad explanation (trying to get the hang of this forum), but you have repreduced what i have a problem with exactly.
It is not major, just annoying as explained.
Bamo
Bamo
Thank you! Fixed.
Regards.
Regards.
