failing evaluation under vectorize()
failing evaluation under vectorize() - Messaggi
#1 Pubblicato: 22/11/2023 01:22:45
Gruppo: Moderator
Why does the vectorize operation fail while it seems to be safe to use an explicit loop?
6-2-Bug.sm (27,78 KiB) scaricato 1667 volta(e).
#2 Pubblicato: 22/11/2023 02:41:12
Hi Martin. Because you have just only one function which can't be vectorized: the norme or dot product of vectors.
sergio 22/11/2023 04:05:00, Martin Kraska 22/11/2023 04:36:00, ioan92 22/11/2023 04:58:00
#3 Pubblicato: 22/11/2023 04:35:34
Gruppo: Moderator
Is that just by observation or is there a fundamental obstacle?
#4 Pubblicato: 22/11/2023 06:57:58
Hi. I guess that it is fundamental.
Some notes about how other CAS handle this issue.
Pretty old matlab version, from its symbolic toolbox
The help page from the newest version
So, it looks like they have some issues with automatic vectorization.
With maple it is very uncomfortable, you need to use map even for simple cases
Wolfram's solution is very practical: Function with attribute 'Listable' expands over lists
But for make a table you actually need a loop or the Mathematica's Map function.
ioan92 23/11/2023 19:35:00, Martin Kraska 25/11/2023 23:04:00
#5 Pubblicato: 25/11/2023 20:15:21
Why does the vectorize operation fail while it seems to be safe to use an explicit loop ?
Set the demand in local definition mode ...
new(t):=|a(t)
vectorize and equate
6-2-Bug Doctored.sm (29,54 KiB) scaricato 1699 volta(e).
#6 Pubblicato: 25/11/2023 23:17:47
Gruppo: Moderator
Thanks Alvaro and Jean. Here is a reduced working example.
When a scalar function involves scalar products then it must be defined in a line()-block in order to be vectorize()able.
Worksheet13.sm (5,9 KiB) scaricato 1770 volta(e).
Oscar Campo 26/11/2023 18:21:00
