1 pagine (6 elementi)
Bug in the SMAth by copy & paste of any varuable (CTR+C & CTR+V) - Messaggi
This is because the plugin implements
Hence when a plain text is passed the plugin handle the action.
Guess would be needed a "paste as" when multiple plugins are available for such task, with the built-in as default (if any).
public string[] SupportedClipboardFormats => new[] { DataFormats.UnicodeText };
Andrey Ivashov 05/05/2021 18:57:00
WroteThis is because the plugin implements
Hello Davide,
thank you for your answer.
Now I have the dilemma, which plugin is responsible for this effect...
I have to turn on and off each plugin step by step to determine it.
Best regards,
Andrey
Is the plugin that is shown when you paste the data
So in this case is XYPlotRegion probably
I've corrected plug-ins to disable handling of text from clipboard by default (as I see it was activated by mistake because of using the same code templates).
So issue is gone. One just need to update installed plug-ins. Note: the latest SMath Studio beta must be used.
