Find and replace?
Find and replace? - Is this feature available in some plug-in? - Messaggi
#1 Pubblicato: 12/10/2021 09:56:42
fedeghi
fedeghi
25 apprezzamenti in 112 post.
Hi, is anybody aware of a method to find every occurrence of a "variable name" in a document, and replace it with another "new variable name" in every formula/occurence?
We have the built-in "find" (CTRL+F), but as far as I know it cannot replace also.
Does any plugin offer this feature?
Thanks
Bye
#2 Pubblicato: 12/10/2021 10:18:54
No, not as per you demand.
Utilities Matrix Find_Replace.sm (23,75 KiB) scaricato 1241 volta(e).
#3 Pubblicato: 12/10/2021 14:25:51
Gruppo: Moderator
There is F8 key for replacing variable when you are inside of a function, line, etc.
But there is not a global search and replace as far as I know.
#4 Pubblicato: 12/10/2021 14:56:27
127 apprezzamenti in 342 post.
As a "sm" file is essentially an XML file, you can open it with an intelligent text editor (notepad ++) and do all the replacements with a special command
fedeghi 12/10/2021 15:54:00
#5 Pubblicato: 12/10/2021 15:56:31
fedeghi
fedeghi
Thanks Overlord, I forgot to mention that I was referring to global "environment" instead of local variables inside a function
Thanks Sergio, I will give it a try, didn't think at this method
#6 Pubblicato: 12/10/2021 16:11:30
#7 Pubblicato: 12/10/2021 16:14:15
Gruppo: Moderator
Text Region Utilities?
File non trovato. File non trovato.
fedeghi 12/10/2021 16:45:00, francesco rapuano 12/01/2025 17:40:00
#8 Pubblicato: 12/10/2021 16:44:38
fedeghi
fedeghi
Super! As usual...
#9 Pubblicato: 12/10/2021 17:39:35
Gruppo: Moderator
I wasn't using this on linux so totally forgot it.
While I was not using Search and Replace has been added.
It must be very long time since I had used it.
When I tried search&replace on linux there is that bug again.
Little blank squares are added front and end of variable.
Same cosmetic bug of Numeric UpDown Region.
But this time it effects variable names, not just cosmetic.
#10 Pubblicato: 13/10/2021 04:21:57
fedeghi
fedeghi
Davide, is there a way / syntax that allows "Text Region Utilities" plugin to substitute some text with a new text containing greek letters?
Example:
Thanks, bye
#11 Pubblicato: 13/10/2021 07:41:58
Gruppo: Moderator
That's odd, nothing more than what you set as replacements should be added; I'll investigate it.
You can use regular expressions, like this:
The syntax means:
SEARCH anything that starts (^) with (S) and a subscript (\.) and capture anything after it ((.*)) [parethesis are the "capture" group, the period means "any character" and the asterisk "zero or more times"; BTW the subscript symbol is escaped with \ because otherwise it means "any character" )
REPLACE with sigma (σ) a subscript (.) and the first of the captured strings ($1)
This might be simplified or much more complicated depending on the cases (what is available on the worksheet and the patterns)
More on regular expressions: C# Regular Expressions
A nice tool to test patterns, with live preview: regex101.com
#12 Pubblicato: 13/10/2021 09:09:56
fedeghi
fedeghi
OK Davide, that's more or less the goal I had in mind, I'll need some more study about the proposed notation but you put me on the right path, thank you.
