Operation cannot be performed with units and solution exceeding max allowed numerical values
Operation cannot be performed with units and solution exceeding max allowed numerical values - Messaggi
#1 Pubblicato: 17/11/2015 14:47:22
aero
aero
0 apprezzamenti in 12 post.
I am getting the error of "Operation cannot be performed with units but I redefined the values with new variable names which has no unit but I am still getting the same error. I need suggestions to resolve this issue. I have attached the Smath file and a screen shot of the same.
Thanks !
#2 Pubblicato: 17/11/2015 17:01:25
Ernesto
Ernesto
13 apprezzamenti in 74 post.
Post the file.
#3 Pubblicato: 17/11/2015 17:07:51
dio pants
dio pants
16 apprezzamenti in 180 post.
What is this a calc of? Do you have a good known example to check against?
Check your operations- calcs dependent on variables need to be below or to the right.
Your units are goofy. break out a pencil and paper and do the dimensional analysis to see how your calc is working, or really not working. SMath is REALLY good at keeping track of units. it is doing exactly what you are telling it to do.
#4 Pubblicato: 17/11/2015 20:23:20
Gruppo: Moderator
Seems that tanh(x) returns a "number above the max" error if x > 354, a "division by 0" error if x < -228 (reported as BUG SS-2284)
About the units, the tanh argument must be dimensionless; m*Lc can't be dimensionless because m is not the inverse of a length (your definition of m contains the Boltzmann constant and 2 lengths)
#5 Pubblicato: 18/11/2015 04:40:35
Gruppo: Super Administrator
Hello.
I've fixed this issue and here is corrected SMath.Math.Numeric.dll SMath.Math.Numeric.dll.7z (25,23 KiB) scaricato 770 volta(e).
Please put it into installation directory of SMath Studio.
Fix will be included into new version of the program.
Regards.
4 utenti hanno apprezzato questo post
Davide Carpi 18/11/2015 05:18:00, sergio 18/11/2015 05:48:00, Radovan Omorjan 18/11/2015 06:22:00, ioan92 18/11/2015 09:16:00
