Matrix element
Matrix element - Calculating with arrays - Messaggi
#1 Pubblicato: 19/11/2013 13:15:38
Henrique
Henrique
1 apprezzamenti in 17 post.
Why it doesn't work on SMath ? It works fine on MathCAD 14.
Matrix element
#2 Pubblicato: 19/11/2013 17:49:17
IVR
IVR
3 apprezzamenti in 15 post.
1. Read program's documentation
2. Use for loop
#3 Pubblicato: 20/11/2013 07:16:34
mb10
mb10
9 apprezzamenti in 20 post.
#4 Pubblicato: 20/11/2013 07:22:20
Henrique
Henrique
I didn't find anything about calculating with arrays in this way. And it's not necessary to use loop as i won't test anything. In addition to typical linear algebra calculations, arrays in Mathcad are useful for performing calculations repeatedly over a range of values. See in the first image another SMath example and in the 2nd image how Mathcad does it:
#5 Pubblicato: 20/11/2013 12:03:09
Gruppo: Moderator
SMath cannot handle vector-valued indices in expressions (AKA "range variables" in Mathcad). Therefore you MUST use loops or you rely on functions from 3rd party plugins like matlab c++ library by uni or Maxima, where nearly all functions can be applied to vectors (without indices). Your example reveals that you might not be aware of the difference between text indices and adress- or array indices.
Most of the tutorials for SMath adress this issue, as this is a very common pitfall for newbies.
Section matrix elementwise.sm (35,55 KiB) scaricato 1594 volta(e).
#6 Pubblicato: 21/11/2013 12:13:51
Henrique
Henrique
My intention was to reproduce in SMath Studio operations with vectors as in Mathcad. I understand you, but on Mathcad there is no problem to do like that. Besides, only now I'm working with SMath, and I also learning on how to use the program.
