Clipboard Region
Clipboard Region - Messaggi
#21 Pubblicato: 08/12/2025 12:59:40
zhkz
zhkz
3 apprezzamenti in 14 post.
PLEASE REPORT HERE ANY ISSUE
hi Davide
glad to find this extension ,but it seems dont work when export value
for export variable value , click Right-pointing triangle then it comes to an error , nothing copied to clipboard
for import value to variable , click left-pointing triangle then it works as expect
I'm not sure if the problem is on my end or with the plugin.
#22 Pubblicato: 09/12/2025 18:13:52
Gruppo: Moderator
Hello, I'll check it, at first glance seems an error plugin-side.
#23 Pubblicato: 11/04/2026 06:49:46
Norrah_Casper
Norrah_Casper
0 apprezzamenti in 6 post.
This is honestly such a lifesaver for moving data between SMath and Excel. Even with the occasional formatting quirks with negative values or scientific notation, it’s much faster than manual entry. I've found that using a quick 'str2num' or 'strrep' usually clears up those string issues in a pinch.
#24 Pubblicato: 27/04/2026 11:27:38
Gruppo: Moderator
hi Davide
Found the issue, fixed code uploaded in the SVN. Can't release the plugin because (I think) there is an issue server side on the relase manager.
Citazione
warning MSB4243: The NuGet-based SDK resolver failed to run because NuGet assemblies could not be located. Check your installation of MSBuild or set the environment variable "MSBUILD_NUGET_PATH" to the folder that contains the required NuGet assemblies
possible solution (for Andrey/the devs): https://stackoverflow.com/questions/79259398/the-nuget-based-sdk-resolver-failed-to-run-because-nuget-assemblies-could-not-be
Modificato 27/04/2026 11:36:11
sergio 27/04/2026 15:44:40
#25 Pubblicato: 28/04/2026 13:53:52
SMath Israel
SMath Israel
4 apprezzamenti in 2.724 post.
Gruppo: Administrator
Dear David,
The finding was caused by new project format. Andrey performed necessary adjustments. You may finish your work now.
Gleb
Davide Carpi 28/04/2026 13:58:05
#26 Pubblicato: 28/04/2026 13:59:58
Gruppo: Moderator
Thank you very much!
Plugin updated
Andrey Ivashov 28/04/2026 15:37:50
