wrong handling of units
wrong handling of units - Measure Units - Messaggi
#1 Pubblicato: 02/05/2018 11:03:27
jaguar3
jaguar3
0 apprezzamenti in 4 post.
I have a problem. Why does Gy or J appear near tonne?
NH.3_ex_c_r:NH.3_ex_c*M.ex_c=1227.6454 Gy tonne
NH.3_ex_c_r:NH.3_ex_c*M.ex_c=1.2276*10^6 J tonne
#2 Pubblicato: 02/05/2018 12:37:53
Arie
Arie
94 apprezzamenti in 285 post.
Hi Adis,
We'll need more information to help you. could you please post the .sm file you're referencing?
#3 Pubblicato: 02/05/2018 16:23:48
"tonne" reminds me a Mathcad bug in the German version.
It also appeared in the Mathsoft "Fourier model" English US version.
#4 Pubblicato: 03/05/2018 04:47:19
jaguar3
jaguar3
Hi Adis,
Proiect master MB1.sm (38,93 KiB) scaricato 1398 volta(e).
#5 Pubblicato: 03/05/2018 07:11:31
Gruppo: Moderator
In your file I can't find neither NH.3_ex_c nor M.ex_c
#6 Pubblicato: 03/05/2018 07:34:53
jaguar3
jaguar3
Sorry wrong files.
Problem.sm (105,05 KiB) scaricato 1409 volta(e).
Real result is 1.2276 tone. 1 tone = 1000 kg
#7 Pubblicato: 03/05/2018 11:03:34
Arie
Arie
I think i fixed the issue. See attached.
I have disabled some of your manual unit definition and performed some cleanup.
Generally you do not want to overwrite units already defined within Smath and you were re-defining already defined units.
The issue, I believe came with your definition of H.ii_c. You applied units to the result and toggled ignore units. This made it seem like the result evaluated to kJ/kg when in fact it was unitless.
This propagated through to the result in question.
Problem_alyles.sm (120,74 KiB) scaricato 1412 volta(e).
#8 Pubblicato: 03/05/2018 11:33:53
Above my head ! why do we still have tonne ?
For God sake what's that in Smath ?
What was it in Mathcad ?
What is the difference between "Titration and MassBalance" ?
In case of interest, PseudoInverse works fine in Smath.
Matrix PseudoInverse.sm (111,21 KiB) scaricato 1418 volta(e).
#9 Pubblicato: 03/05/2018 11:40:41
Arie
Arie
1 tonne is defined as 1000 kg. Same thing as a Mg.
#10 Pubblicato: 03/05/2018 12:12:18
Thnks alyless,
ton(long), ton(short), tonne(metric)
#11 Pubblicato: 03/05/2018 13:05:51
Gruppo: Moderator
ton(short)
short is t
#12 Pubblicato: 04/05/2018 01:10:03
jaguar3
jaguar3
Thank you very much! The original file was worked in Mathcad. After conversion to SMath Studio, some errors occurred. In the future, I will only use the defined units.
#13 Pubblicato: 04/05/2018 01:26:54
Oh !, you are the man of science in there.
I know about titration from past professional [Process Control & Instrumentation]
Not so easy ... so and so ... generally Ph control.
Did you visit PseudoMatrix ? Any use for your project ?
