1 pagine (7 elementi)
Resolving functions based on other functions in SMath Studio - Mathcad Prime - Liquid Flow Through a Pump - Messaggi
hi guys it's me again xD
There is an exercise to find the discharge speed of a pump in Mathcad Prime ... when I try to do it in SMath Studio I am unsuccessful
I leave the pdf of Mathcad Prime and the SM File
Liquid Flow Through a Pump.sm (42,2 KiB) scaricato 1226 volta(e).
FlowThroughaPump.pdf (690,73 KiB) scaricato 857 volta(e).
It didn't seem that difficult. Attached as far as I could advance.
Liquid Flow Through a Pump.sm (46,99 KiB) scaricato 1198 volta(e).
Wrotewhen I try to do it in SMath Studio I am unsuccessful
These 3 documents may have interest in your projects.
I have Control Valve Sizing as well.
Your first PUMP fails the Table ... incorrect format ???
Inst_Colebrook MOODY.sm (16,88 KiB) scaricato 1253 volta(e).
Inst_Colebrook Pipe Data.sm (71,45 KiB) scaricato 1239 volta(e).
Inst_Colebrook.sm (167,25 KiB) scaricato 1235 volta(e).
Hi. Solved.
Liquid Flow Through a Pump.sm (51,06 KiB) scaricato 1232 volta(e).
Liquid Flow Through a Pump.pdf (126,32 KiB) scaricato 779 volta(e).
WroteThere is an exercise to find the discharge speed of a pump
This document is metric, you can convert imperial.
There is more than velocity for the plant Manger
wrt power consumption and optimum plant operation.
Jean.
Inst_Colebrook Pipe Data.sm (71,45 KiB) scaricato 1227 volta(e).
