Poisson's equation - Ordinary Differential Equation Solve - Messaggi
The first difficulty: I don’t know how to correctly write the boundary conditions for pnet on page 7.
I will be very grateful if you can help me.
Built-in potential_3.sm (31,27 KiB) scaricato 1148 volta(e).
Notice that you can use units in SMath, which is a very powerful tool detecting issues in practical calculus. For instance, here I don't know how to handle ni, which have units of cm^-3, and I need to introduce that factor as a correction for the bias potential, but using meters, not centimeters. Check that, please.
Built-in potential_3.sm (48,21 KiB) scaricato 1182 volta(e).
Built-in potential_3.pdf (170,75 KiB) scaricato 838 volta(e).
WroteHi. You have "true" boundary conditions in 2 or 3D, but in the one dimensional case you can integrate rho between -inf and +infinity. Given that the field is zero outside the interval (-Wp,Wn) you can set the bounds as (-Wp,0) and (0,Wn) and integrate rho for each interval, which is the integral of a constant.
Thank you very much, now I almost all understand. Also thanks for the unit hint. Instead of centimeters, there should be nanometers. But SmutnStudio gives Ф/m, but we need nm. Interestingly, in the program you can somehow change the meters to nanometers. In the last formula (potential), I removed the minus sign and everything became as it should.
The data I took from this document. (https://lampx.tugraz.at/~hadley/psd/problems/pn/S.pdf)
Thank you very much for your help, I am very grateful to you.
Wrote...
Ah, yes: Na, Nd have units, are number of charges by cm^3, I forgot that. Now there are not any mysterious unit factor in the formulation, and have the same answers than in the manual calculus from the pdf.
Built-in potential_3_with_Na_Nd_units.sm (51,55 KiB) scaricato 1191 volta(e).
Built-in potential_3_with_Na_Nd_units.pdf (183,82 KiB) scaricato 803 volta(e).
