Curve fitting function
Curve fitting function - Is there a curve fitting function in Smath? - Messaggi
#1 Pubblicato: 13/01/2022 07:38:26
rex
rex
1 apprezzamenti in 10 post.
Is there any curve fitting function in Smath?
I mean using the defined points to find the function of these points!
Thanks a lot!
#2 Pubblicato: 14/01/2022 00:00:26
rex
rex
... for best examination: close Smath ... open a virgin session.
This way, as you will download, both will be resident in same session.
Open include to inspect the content, close back.
Open Test UpDated ... F9 to run
Test Updated contents 5 stand alone fit examples.
If it does not work wrt your Smath version ... bug.
Try it ... report ... Jean
Genfit Algo Include.sm (36,12 KiB) scaricato 1364 volta(e).
Genfit Algo Include Test UpDated.sm (145,48 KiB) scaricato 1344 volta(e).
Hi Jean,
Thanks for your reply!
I tired the .sm file, but it doesn't work well. Meanwhile, the Genfit Algo Include.sm needs rename as GenfitAlgoInclude.sm.
I put the two .sm files in the same location, tSmath_error.pnghen I opened the Test Updated.sm, and pressed F9 to run....the error is shown in the picture.
The information of my Smath is Version 0.99
Looking forward to your feedback, thanks!
[attach]42964
#3 Pubblicato: 14/01/2022 00:53:11
CBG
CBG
78 apprezzamenti in 312 post.
Hello
Maybe you can deal with Least Squares Fit
Define_a_Variable_Ajust_by_Last_Square.sm (58,17 KiB) scaricato 1455 volta(e).
Ajust_by_Last_Square_Selection.sm (54,44 KiB) scaricato 1331 volta(e).
Carlos
#4 Pubblicato: 14/01/2022 02:04:40
Gruppo: Moderator
Answer is YES
I don't know an embedded function for this.
But you can write your own function.
Lagrange Interpolation Method can be used.
maple() command is not necessary but it simplifies the function.
Giving more points, curve gets more complex.
Here is some examples for your request.
lagrange.sm (26,56 KiB) scaricato 1322 volta(e).
Click to enlarge
Click to enlarge
Click to enlarge
Click to enlarge
sergio 14/01/2022 06:15:00, Alvaro 14/01/2022 16:19:00
#5 Pubblicato: 14/01/2022 02:55:13
rex
rex
Hello
Carlos
Hi Carlos,
This works really fine, thanks for sharing this!
#6 Pubblicato: 14/01/2022 02:57:10
rex
rex
Answer is YES
Click to enlarge
Click to enlarge
Click to enlarge
Click to enlarge
Hi, thanks for sharing this, I will try to learn your file!
#7 Pubblicato: 14/01/2022 05:36:56
Gruppo: Moderator
Thanks a lot!
Maxima plugin has the Fit() function, see this post
In the interactive handbook, you find it in the Function Index page.
#8 Pubblicato: 14/01/2022 06:56:58
Hi. Some fitting curves functions in the attached.
fit.pdf (527,19 KiB) scaricato 983 volta(e).
fit.sm (377,47 KiB) scaricato 1374 volta(e).
NDTM Amarasekera 14/01/2022 11:23:00, sergio 14/01/2022 07:23:00, Fridel Selitsky 14/01/2022 07:26:00
#9 Pubblicato: 14/01/2022 10:56:33
Gruppo: Moderator
You are welcome.
My function is direct method, may not be suitable for large data sets.
Razonar's and mkraska's samples are good to investigate too for that purpose.
#10 Pubblicato: 14/01/2022 16:25:17
Hi ovlerlord.
Answer is YES
Yes, it is YES.
This version of your application doesn't need maple for get the simplified lagrange polynom.
lagrange.sm (22,88 KiB) scaricato 1324 volta(e).
overlord 14/01/2022 17:46:00, usamakhan 31/10/2026 08:27:00
#11 Pubblicato: 17/01/2022 00:15:21
rex
rex
Hi Jean,
Please, attach your raw data set., i.e: not freaked by else.
Two more examples attached.
Genfit Frechet DIFFICULT.sm (128,06 KiB) scaricato 1309 volta(e).
Genfit Kirby_2 [Reduced] Copy.sm (81,39 KiB) scaricato 1138 volta(e).
A fitting session is mostly governed by the model and techniques.
In short: sky is the limit. Some data set can only be fitted by hand.
Plenty are willing in Smath Community.
Take care ... Jean
Hi Jean,
see the stress-strain data, I would say I am really happy about this forum. I got a lot of fit function information from here! Thanks all!
#12 Pubblicato: 17/01/2022 04:55:01
Hi. Three fitting models for your data.
fit_stress_strain.sm (523,68 KiB) scaricato 1354 volta(e).
fit_stress_strain.pdf (635,91 KiB) scaricato 946 volta(e).
Fridel Selitsky 17/01/2022 05:00:00
#13 Pubblicato: 17/01/2022 05:58:00
rex
rex
Wow, it's amazing!
Thanks Alvaro!
#14 Pubblicato: 26/01/2022 18:21:34
Hi Jean,
I tried the .sm file, but it doesn't work well.
You have detected a bug wrt your SS version, maybe earlier ones ?
Silent Smath Community ?
If you open the governing Conjugate Gradient ... it could be
the symbolic module has not been saved Symbolic, a common bug reported.
By same token, I will delete all previous attachments.
Please, don't hesitate ... Take care ... Jean.
I guess your original raw data is the one from Alvaro ?
