Unicode issue in string argument for image2rgb()
Unicode issue in string argument for image2rgb() - Messaggi
#1 Pubblicato: 22/04/2021 00:44:39
Hi. The error is self explained.
This is the saved file:
Davide Carpi 22/04/2021 08:36:00
#2 Pubblicato: 22/04/2021 08:36:07
Gruppo: Moderator
Thank you, I'll fix it ASAP.
#3 Pubblicato: 25/04/2021 19:48:26
Gruppo: Moderator
Fixed and released for the latest beta
Alvaro 25/04/2021 20:09:00
#4 Pubblicato: 25/04/2021 20:21:10
Hi Davide. The issue persists for release "0.99.7786.571":
test.sm (2,38 KiB) scaricato 1475 volta(e).
#5 Pubblicato: 26/04/2021 04:38:06
Gruppo: Moderator
It works for me even if dots, slashes and underscores are encoded
#6 Pubblicato: 26/04/2021 08:53:32
Hi Davide. Yes. you're right, it works with encoded strings now, I see the strings, and no check if can read files with that.
So, standard ASCII characters lower than 128 will be encoded as Unicode? That can introduce a lot of issues for low level manipulation to the user.
test_unicode_2.sm (5,82 KiB) scaricato 1531 volta(e).
Also, the string "a_b" doesn't appear in the search box, but if you search for x, x and "x" appear.
Also, suppose that I want to find an sm file where it's defined the function "my_function_1": I need to search now the string "my\005F\function\005F\1" inside the files?
sergio 26/04/2021 14:05:00
#7 Pubblicato: 26/04/2021 10:31:56
Gruppo: Moderator
As Andrey has stated there's an enforcement on the encoding, I don't know how much can be relaxed (as positive thing now you should be able to use 4-digits folders in paths); however as you pointed out in some fields the program misses the proper implementation to deal with them (more visible because the enforced rule, but would have been buggy even with less strict approach, and it was buggy since the encoding was already in place). Ideally it should works flawlessy whatever under the hood all character are encoded or not.
Alvaro 26/04/2021 10:57:00, sergio 26/04/2021 14:05:00
#8 Pubblicato: 26/04/2021 11:38:33
Gruppo: Super Administrator
Alvaro,
Thank you! Fixed.
Alvaro 26/04/2021 23:45:00
