sum over range is terribly slow
sum over range is terribly slow - Messaggi
#1 Pubblicato: 28/03/2018 04:48:19
Ave Zoid
Ave Zoid
0 apprezzamenti in 3 post.
debug.sm (12,2 KiB) scaricato 1167 volta(e).
While doing a sum on a floating-point range I have realized simple SUM(4) cannot be directly used
It requires translation of FP range into the integer range, which is basically a hack.
Doing a sum over the FP range in a loop is terribly slow - any ideas why?
#2 Pubblicato: 28/03/2018 05:04:43
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
Use Optimization --> Numeric on the function.
(R/Click on the function, select Optimization ---> Numeric.
#3 Pubblicato: 28/03/2018 05:38:37
Ave Zoid
Ave Zoid
That worked. Thanks!
#4 Pubblicato: 28/03/2018 09:28:35
I don't see that here. "for loop" is always the winner. deeper @ kernel level.
debug [doctored].sm (12,28 KiB) scaricato 989 volta(e).
#5 Pubblicato: 29/03/2018 09:30:19
Ave Zoid
Ave Zoid
AS NTDMA has suggested, Numeric Optimization did the trick. Its was purely to do with my incompetence.
