mcdconv_tool_v5.zip (67,06 KiB) scaricato 34 volta(e).OK. Here is my first try. It appears to work correctly for the two or three old worksheets for which I had pdf print-outs as well as the original .mcd files. I also fed it the worksheets for Krieth Principles of Heat Transfer. At the time, I was using WaterSteamPro for properties of water, air and products of combustion for my own designs; hence some references to wsp.
If you get Claude to make significant additions to the method, e.g. confirming additional details in the binary file code, please share here.
Modificato 30/10/2026 13:32:48
