subscript in text region
subscript in text region - subscript - Messaggi
#1 Pubblicato: 20/03/2019 15:31:49
The Cross
The Cross
0 apprezzamenti in 73 post.
How do I put in a subscript below a letter in a text region?
#2 Pubblicato: 20/03/2019 15:37:44
Arie
Arie
94 apprezzamenti in 285 post.
If you use writer region plugin, you can use Ctrl+Shift+B. You can install writer region by going to tool->Plugins->Clicking on Local Storage and choosing Online Gallery -> Scroll to Writer Region and double click to install.
I'm not sure if the built-in text region handles subscripts.
#3 Pubblicato: 20/03/2019 15:47:46
The Cross
The Cross
I added it, but if I hit Ctrl+Shift+B, in the text region, nothing happens.
#4 Pubblicato: 20/03/2019 15:56:45
Arie
Arie
To add a writer region to your sheet use crtl+shift+w.
Then you can type as usual.
Note: If you right click on the writer region and choose settings, you get a microsoft word-like toolbar.
#5 Pubblicato: 20/03/2019 16:04:00
... from there, drag the ribbon down the work sheet,
select the letter(s), number(s) you want to subscript,
click on the icon that shows subscript ... try.
Generally you will to increase the font size of the subscripted.
#6 Pubblicato: 20/03/2019 16:17:52
The Cross
The Cross
Thanks. The person next to me, got a message that the text writer region could not be added and to remove it, but it worked for me.
#7 Pubblicato: 20/03/2019 16:31:09
Arie
Arie
Are yall running the same version of SMath? Did it fail when they tried to install writer region or when they tried to add a writer region using ctrl+shift+w?
#8 Pubblicato: 20/03/2019 16:38:05
The Cross
The Cross
He picked the wrong addin. It is working now.
