combining arrays
combining arrays - Messaggi
#1 Pubblicato: 11/01/2022 11:21:07
1986max
1986max
0 apprezzamenti in 9 post.
Tell me please.
Question - 1
There are several arrays. a=[1;2...4], b=[7;8..10], c=[12;13...15]
How do I combine them so that it turns out as follows - d=[1,2,3,4,7,8,9,10,12,13,14,15]
Question - 2
There is an array a=[1;2...10], I need to exclude several values from it so that it turns out as follows a=[1,2,5,6,7,9,10]
q-1-2.sm (3,71 KiB) scaricato 1255 volta(e).
#2 Pubblicato: 11/01/2022 13:12:55
127 apprezzamenti in 342 post.
One way (stack use)
q-1-2_ser.sm (6,18 KiB) scaricato 1323 volta(e).
Andrey Ivashov 11/01/2022 15:23:00
#3 Pubblicato: 11/01/2022 13:51:29
Question - 2
Make it algo style, add/remove cols.
This way you will have in-situ as desired.
Welcome to Smath Community ... Jean.
#4 Pubblicato: 12/01/2022 03:58:49
1986max
1986max
thank a lot, all options are excellent!)
#5 Pubblicato: 12/01/2022 10:26:33
Thank a lot, all options are excellent !
Appreciated ... more in there ... Jean.
Utilities Matrix Extractors.sm (56,76 KiB) scaricato 1264 volta(e).
sergio 12/01/2022 11:17:00
#6 Pubblicato: 14/01/2022 15:06:20
Gruppo: Moderator
In addition to sergio's answer, you can use an custom exclude function.
It will remove substances of a L# list from master M# list.
exclude.sm (5,92 KiB) scaricato 1205 volta(e).
