RC2: SMath Studio 0.98.6089 (02 September 2016)
RC2: SMath Studio 0.98.6089 (02 September 2016) - Messaggi
#1 Pubblicato: 02/09/2016 09:09:55
Gruppo: Super Administrator
Release Candidate: SMath Studio 0.98.6089 available
Latest changes (against SMath Studio 0.98.6083)
  • Fixed handling of directories in plug-ins archives when plug-in installed from Extensions Manager;
  • [SS-2345]: Fixed toolbox invisible items;
  • Fixed white background while buttons contains drawings;
  • [SS-219]: Required parenthesis automatically added in some cases for el(...) function;
  • [SV-2373], [SV-2377]: Wrong handling of encrypted areas by Viewer and related crashes are fixed;
  • [SV-2376]: Case-sensitive function listing restored in Insert Function dialog;
  • Back-compatibility issue fixed: it was impossible to work with data loaded by rfile(...);
  • It is possible now to paste one-line text into MathRegion.
Download
9 utenti hanno apprezzato questo post
Mike Kaganski 02/09/2016 09:15:00, Вячеслав Мезенцев 02/09/2016 09:27:00, sergio 02/09/2016 09:39:00, Christopher Bietz 02/09/2016 09:45:00, Radovan Omorjan 02/09/2016 10:25:00, NDTM Amarasekera 02/09/2016 10:53:00, Davide Carpi 02/09/2016 11:42:00, Martin Kraska 03/09/2016 07:23:00, Serg 03/09/2016 13:39:00
#2 Pubblicato: 03/09/2016 07:23:17
Gruppo: Moderator
Section Math ODE intro.sm (26,43 KiB) scaricato 1810 volta(e).
If I try to open the attached document, the plugin dependency dialog complains about the missing ODE Solver. The requested version in the dialog is older than the one actually installed. It seems that the message can be ignored safely.
Not sure if that is a feature...
#3 Pubblicato: 05/09/2016 11:17:50
Hello.
Not sure why, but on 17 August 2015 [USERLINK]uni[/USERLINK] changed version of ODESolvers plug-in from 1.0.* to 0.1.*.
This is not a good practice because in software development it is always supposed that newer build means increased version.
Because of that challenge SMath Studio cannot understand what happened with this plug-in and displays an error dialog to show that something unusual happens.
This also means that those who installed ODESolvers plug-in before 17 August 2015 will never see any updates of this plug-in and will always use outdated version. That is why I think SMath Studio message you mentioned is a good thing. I suggest to delete installed version of ODESolvers plug-in (using Extensions Manager - select plug-in and press uninstall button at the bottom of the dialog) and then install it again.
Best regards, Andrey Ivashov.
Davide Carpi 05/09/2016 13:18:00
#4 Pubblicato: 05/09/2016 14:03:43
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
My mistake, sorry for this. I forgot why I did it.
