Roark Mathcad interactive Book
Roark Mathcad interactive Book - Messaggi
#1 Pubblicato: 20/09/2019 04:53:14
pierre
pierre
2 apprezzamenti in 17 post.
Hi there,
As was wondering if their is any way to open the "Roark’s formulas for Stress and Strain" mathcad handbook?
Roark's Formulas Stresses Strain 6ed Mathcad Handbook (same as the ZIP archive).rar (9,4 MiB) scaricato 775 volta(e).
#2 Pubblicato: 20/09/2019 05:49:21
Gruppo: Moderator
They are .mcd binary files, there's no way to open them because are encoded in a prorietary format.
#3 Pubblicato: 20/09/2019 06:01:15
pierre
pierre
Ok,
Thank you a lot for the fast answer.
#4 Pubblicato: 20/09/2019 08:10:12
I was wondering if there is any way to open the "Roark’s formulas for Stress and Strain" mathcad handbook?
My answer is NO ... Smath is not a Mathcad clone.
What I have from Mathcad 8 Pro up to Case 12.a
All that stuff are only formulas, but not only formulas.
Each example, thus each eventual application case
are base on the solve bloc Given/Find [linear]
Smath does have such coded solver.
Very many Mathcad Given/Find have been solved in Smath
via its own solver. Best example is Frobenius, Quaternion ...
I see no problem making an Smath Roark, quite a project.
It should be no problem adapting the units ISO [metric].
Put the stuff up to Case 5a in Smath document,
attach in this Forum for eventual collaboration.
#5 Pubblicato: 20/09/2019 10:24:36
Smath does not have ...
#6 Pubblicato: 20/09/2019 20:52:01
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
It is possible, but you need to convert all mcd files to xmcd format. You can do it manually using Mathcad 11. After that you can try open xmcd files in SMath Studio.
frapuano 21/09/2019 02:51:00
#7 Pubblicato: 20/09/2019 23:37:10
That stuff is Mathsoft from Mathsoft, i.e: from Mathcad.
The collab has that stuff, just to be converted Given/Find.
Smath is not going to convert Given/Find.
That bloc is Mathsoft property.
I'm saying that because you are suggesting Smath will run.
#8 Pubblicato: 25/05/2023 12:03:02
pierre
pierre
Dear all,
I took some time rewriting the roark for Smath,
It is not finished yet, and I am still working on it on my spare time, as it improve both my understanding of smath, and structural calculation.
Many calculations can be done in other way, and if pple find a faster, or more interesting way to solve some equation/problems, i would be really interested, and integrate it.
roark v0.1.7z (1,52 MiB) scaricato 896 volta(e).
One last question:
My aim is to make an handbook, how can i perform this?
Thankyou,
Pierre
#9 Pubblicato: 25/05/2023 14:46:00
Hello Pierre,
Simply attach your *.sm document to read at opening.
Thanks, Jean.
#10 Pubblicato: 25/05/2023 15:18:09
CBG
CBG
78 apprezzamenti in 312 post.
Hello
I think the interactive book query can help you
Carlos
#11 Pubblicato: 26/05/2023 04:24:31
Gruppo: Moderator
Dear all,
One last question:
Thankyou,
Pierre
The links in your book don't work for me. It seems that batch production of links using the toolbox from the text region utilities plugin don't produce valid links any more.
So you might have to edit the xml file as I had to when I started to create the interactive handbook.
#12 Pubblicato: 26/05/2023 15:02:35
basri
basri
0 apprezzamenti in 5 post.
Hi, I am new Smath. I was trying to open Mathcad file (.xmcd). The page went blank. Would you help? Thank you.
