1 pagine (4 elementi)
A function for finding constrained minimum - mb10@live.it - Messaggi
Attached is a snippet function for calculating the constrained minimum of a scalar function J(x) of several variables.
More specifically it solves the problem:
minimize J(x) in the domain xm <= x <= xM
subject to:
g(x)>=0; (a vector function of m potentially nonlinear inequality constraints)
A*x = b; (r linear equality constraints, A being an rxn matrix)
The algorithm has been adapted from this article (in particular from eqn. (7) on page 4):
http://www.ajbasweb.com/ajbas/2011/894-909.pdf.
minimizerExamples_v01.sm (39,4 KiB) scaricato 1664 volta(e).
subject to:
I attached a version with function arguments. In the definition, the formal parameter is a function name with the numbers of arguments given, in the call the actual parameter is the function with an UNDEFINED variable as dummy argument, Thus, minimize(J(x), g(x), x ... won't work because x is bound to the initial values vector.
minimizerExamples_Kr.sm (38,12 KiB) scaricato 1696 volta(e).
Radovan Omorjan 12/09/2013 16:16:00
@ Martin Kraska:
With your changes (and changing the names in the body of the algorithm as well), it seems to work fine now, and I will soon update both files accordingly.
Thank you very much for your explanations!
mb
mb
