Animation of mechanisms
Animation of mechanisms - Ber7 - Messaggi
#21 Pubblicato: 27/07/2012 23:31:39
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
Drilling a square hole (Cross section of the drill is Reuleaux triangle)
Reuleaux triangle is rotated around its center of gravity, and the center of gravity
moves around the center openings.
https://smath.com/wiki/GetFile.aspx?File=Reuleauxtriangle.rar
Davide Carpi 28/07/2012 12:50:00, ioan92 18/05/2013 07:48:00
#22 Pubblicato: 05/08/2012 03:13:02
Fridel Selitsky
Fridel Selitsky
Drilling accurate (without rounding) square hole
The disc in the form of a modified Reuleaux triangle
moves inside a square frame . A drill (green dot in the center
of the yellow circle) makes an exact square hole.
References:
Wagon S. Mathematica in Action: Problem Solving .
Through Visualization and Computation,Springer, 2010
https://smath.com/wiki/GetFile.aspx?File=Drilling2.rar
Davide Carpi 05/08/2012 12:09:00, ioan92 18/05/2013 07:48:00, Andrey Ivashov 05/08/2012 07:49:00
#23 Pubblicato: 13/08/2012 15:19:53
Fridel Selitsky
Fridel Selitsky
Square-Hole Drill (continued)
Using the coupling Oldham to convert the rotational motion
of the drive shaft to move the tool to the square trajectory.
https://smath.com/wiki/GetFile.aspx?File=SquareHole.rar
Davide Carpi 14/08/2012 05:20:00, Andrey Ivashov 14/08/2012 18:01:00, ioan92 18/05/2013 07:48:00
#24 Pubblicato: 13/08/2012 15:23:14
Fridel Selitsky
Fridel Selitsky
Davide Carpi 22/09/2012 19:36:00, ioan92 18/05/2013 07:49:00
#25 Pubblicato: 16/08/2012 10:41:24
Fridel Selitsky
Fridel Selitsky
Drill, coupled with the Reuleaux triangle
ioan92 18/05/2013 07:49:00, Davide Carpi 22/08/2012 09:17:00
#26 Pubblicato: 22/08/2012 07:48:08
Fridel Selitsky
Fridel Selitsky
Wankel Engine((rotary-Reuleaux triangle)
Wankel.rar (2,74 KiB) scaricato 613 volta(e).
ioan92 18/05/2013 07:49:00, Andrey Ivashov 22/08/2012 12:40:00, Davide Carpi 22/08/2012 09:17:00
#27 Pubblicato: 22/09/2012 12:07:33
Fridel Selitsky
Fridel Selitsky
Chassis for Mars Curiosity Rover
Soft landing "Curiosity" on the surface of Mars was held August 6, 2012
https://smath.com/wiki/GetFile.aspx?File=Curiosity.rar
ioan92 18/05/2013 07:49:00, Davide Carpi 22/09/2012 19:36:00
#28 Pubblicato: 29/10/2012 06:19:16
Fridel Selitsky
Fridel Selitsky
Rocker-bogie mechanism that can navigate the stairs.C.M.-center of mass.
1.All three wheels are actuated independently.
Climbimg1.rar (4,15 KiB) scaricato 621 volta(e).
ioan92 18/05/2013 07:50:00, Davide Carpi 29/10/2012 07:15:00
#29 Pubblicato: 29/10/2012 06:25:44
Fridel Selitsky
Fridel Selitsky
2. All three wheels are passive and the part of the rocker-bogie mechanism body is pulled
up by the external force as in the case of shopping carts.
Climbing2.rar (4,17 KiB) scaricato 582 volta(e).
Davide Carpi 29/10/2012 07:15:00, ioan92 18/05/2013 07:50:00
#30 Pubblicato: 17/11/2012 06:27:27
Fridel Selitsky
Fridel Selitsky
Planar three-link manipulator
3R.rar (60,06 KiB) scaricato 532 volta(e).
Davide Carpi 03/02/2013 18:04:00, ioan92 18/05/2013 07:50:00
#31 Pubblicato: 07/01/2013 12:58:35
Fridel Selitsky
Fridel Selitsky
Geneva Mechanism
Geneva.smz (40,39 KiB) scaricato 1796 volta(e).
Davide Carpi 07/01/2013 13:21:00, ioan92 18/05/2013 07:51:00
#32 Pubblicato: 03/02/2013 14:26:51
Fridel Selitsky
Fridel Selitsky
Animation kinematic characteristics
Above: The trajectory of the point B, the vectors of its velocity and acceleration;
Below: the dependence of the velocity and acceleration of point B on
crank angle β (t)
kinchar1.sm (37,74 KiB) scaricato 1499 volta(e).
kinchar.smz (11,6 KiB) scaricato 1754 volta(e).
ioan92 18/05/2013 07:51:00, Davide Carpi 03/02/2013 18:04:00, Martin Kraska 03/02/2013 17:08:00
#33 Pubblicato: 04/02/2013 10:55:13
sublim21
sublim21
3 apprezzamenti in 36 post.
Impressive stuff Ber.
#34 Pubblicato: 18/05/2013 06:21:16
Fridel Selitsky
Fridel Selitsky
Robot snake
Worm1.smz (15,36 KiB) scaricato 1664 volta(e).
ioan92 18/05/2013 07:51:00, Davide Carpi 18/05/2013 07:31:00, Andrey Ivashov 18/05/2013 17:56:00
#35 Pubblicato: 28/09/2013 02:45:33
lrcvs
lrcvs
3 apprezzamenti in 2 post.
Hi,Ber7
All your post for moving parts are very, very, very...., goods, fantastics.!
Fridel Selitsky 29/09/2013 10:23:00
#36 Pubblicato: 17/01/2014 06:23:24
Fridel Selitsky
Fridel Selitsky
Animation spatial mechanisms
To calculate the position of the mechanism will use
techniques developed A.B.Ivanov.His work on 3d
animation mechanisms made ​​in Mapl, publishes A.B.Ivanov
online
http://forum.exponenta.ru/viewtopic.php?t=12842
Of the examples from this site I suffered in a programming environment SMath Studio
1. Sarrus linkage 1
Sur111.smz (8,13 KiB) scaricato 1724 volta(e).
Davide Carpi 21/01/2014 18:08:00
#37 Pubblicato: 17/01/2014 06:27:14
Fridel Selitsky
Fridel Selitsky
2. Sarrus linkage 2
Sur3.smz (9,82 KiB) scaricato 1783 volta(e).
Davide Carpi 21/01/2014 13:14:00, Martin Kraska 21/01/2014 18:48:00
#38 Pubblicato: 21/01/2014 13:14:15
Gruppo: Moderator
Nice job ber, as usual
BTW I can't download the first animation (Sarrus linkage 1)
Best regards,
Davide
#39 Pubblicato: 21/01/2014 15:50:29
Fridel Selitsky
Fridel Selitsky
Thank you,Davide,now you can download the file.
#40 Pubblicato: 04/10/2016 15:07:34
Fridel Selitsky
Fridel Selitsky
Sarrus.sm (19,25 KiB) scaricato 1617 volta(e).Sarrus linkage
Short animation program
