Possible bug printing?
Possible bug printing? - Font type changes printing PDF - Messaggi
#1 Pubblicato: 13/05/2020 19:24:20
Alvaro Gavilán-Rojas
26 apprezzamenti in 68 post.
I would rather ask and confirm that this could be a bug report.
In some description texts for variables, when I print PDF, the font type returns to "Courier New", even after changing the font type in the code (notepad).
Is this a bug? Or there is a way to fix this font type when printing?
SMath capture:
Print preview capture:
Code capture:
File:
HA-FUND-ZA.sm (198,83 KiB) scaricato 1387 volta(e).
(SMath Studio 0.99.7030.1435)
Thank you in advance,
#2 Pubblicato: 13/05/2020 19:31:44
The only answer I have:
Print an Smath document on virtual PDF [CutePDT freeware]
Read from Adobe [freware] 1/1 original Smath quality and all.
#3 Pubblicato: 13/05/2020 19:51:16
I tried it, but unfortunately that didn't solve the problem. The problem is already generated in the SMath preliminar view.
#4 Pubblicato: 14/05/2020 01:37:14
Problem solved printing PDF with the latest version of SMath Stuido (0.99.7251)
Davide Carpi 14/05/2020 07:44:00
#5 Pubblicato: 26/05/2021 17:49:13
Alejandro Pérez Lolas
0 apprezzamenti in 4 post.
Hi.
In the most recent version of SMath Studio the font type of the description dialog cannot been changed. It is set by default to Verdana.
Anyone knows a way to change this default setting instead of changing each file in the code?.
In advance thank yor very much.
#6 Pubblicato: 27/05/2021 12:32:23
Yes! I noticed this but did not have time to report. In SS 7808 one can only change the description font type in the file code.
#7 Pubblicato: 27/05/2021 12:49:36
Gruppo: Moderator
Several years ago I asked for this feature, changing font of descriptions.
I just use Courier New for both text, descriptions and functions by the way.
So I gave up with this but sure someone shall get benefit from it.
#8 Pubblicato: 27/05/2021 14:18:27
The font type was largely discussed/experimented in Mathsoft Collaboratory.
Especially Verdana with very little defendable.
Mathcad [8, 11] default equation ... is the poorest type Times New Roman,
prone to confusion mostly wrt the invisible decimal dot. Easy to change
from the font menu.
Native Smath was default best Courrier New for description/formulas/data.
This is so SS 6179, so lovely for publishing uniform book style documents.
#9 Pubblicato: 27/05/2021 19:50:46
Gruppo: Super Administrator
Latest version of SMath Studio always uses Courier New for equations, Descriptions and Area Titles.
Text Region default font is Arial, but it can be easily changed using Fonts drop-down on the toolbar.
#10 Pubblicato: 28/05/2021 11:11:34
Hi Andrey,
Thank you for your fast reply and for developing an amazing tool for math calculations.
I'm curious about the reasson for keeping blocked the possibilty of changing the font type for equations, descriptions and area titles, and if it will be a standard setting for future versions of the software. Is it possible to include a format menu on future versiones for changing the font for equations and others?. In case it wouldn't be possible, could be restored the capability of changing this by modifing the code in the file setting.prop?.
If an economic contribution would help to make the software more user-friendly on this aspect, I would be happy to help.
In advance thank you very much.
#11 Pubblicato: 28/05/2021 12:36:59
Mathcad 11 has about 7 pre-user-defined formulas font.
You can increase no limit to amaze the birds.
Valery used it very few for demo, myself too ... horribly messy !
None Collabs have used it. IMHO, Smath Courrier New is best.
#12 Pubblicato: 28/05/2021 12:55:21
It is just a question of time and priorities. Of course implementation of possibility to change font for equations is planned and it is not something too complex - I have almost everything to do it.
Sorry, didn't know this is broken now. Will check asap.
This kind of voting usually helps To say truth changing Font for equations is not something requested too often, so last several years it was always something to implement "soon". Will check if I can prioritize it...
#13 Pubblicato: 31/05/2021 17:00:23
I've checked modification of settings.prop and it works well.
Regarding implementation of font changing for equations: I've checked everything and see it is a complex thing:
  1. Currently SMath Studio designed to have a single font face for all math equations (because of performance reasons). Code should be redesigned to support more then one font.
  2. It is not clear for me if font for text and for math should be the same on the Worksheet or not? If not, then what UI to implement to allow user changing fonts for text and math against to each other?
So, I decided to spend a time on it after tomorrow's stable release. It is a significant change and we must test it seriously before publishing.
#14 Pubblicato: 31/05/2021 17:51:07
Sorry Andrey, I was not completely accurate. The problem is that now the description text do not change to arial and still on courier new when you change the settings.prop file. Please see the picutre below:
Wow, I believed it was as simple as make a shortcut in the menu bar to the file settings.prop. Thank you very much.
#15 Pubblicato: 31/05/2021 19:26:51
Hello!
Thank you Andrey for reading this topic. It's the first time I can say THANK YOU for SMath Studio. I hope to further collaborate with this wonderful project, I am at the very beggining of this trip, since I heard about SMath Studio on april, 2020.
Regarding comments, I would be grateful if we can have a simpler way of changing description and math default font types in a worksheet.
As a workaround that could help you, Melo15, I attach here an image that could be useful. Saludos!
Hope it helps!
test comment.sm (14,58 KiB) scaricato 1529 volta(e).
Andrey Ivashov 31/05/2021 19:50:00
#16 Pubblicato: 04/06/2021 16:02:13
Hello!
Hope it helps!
Thank you Alvaro.
#17 Pubblicato: 18/05/2023 14:04:06
CLEISON ARMANDO MANRIQUE AGUIRRE
0 apprezzamenti in 2 post.
So you can change the font to be similar to Mathcad Prime ?
