1 pagine (11 elementi)
Newton method - Messaggi
I cannot use the roots function and must use one old good simple method by Newton.
What can you say about it?
Newton-Eng.docx (1,07 MiB) scaricato 993 volta(e).
Martin Kraska 09/04/2023 08:50:00
Very nice.
I had problems when reproducing your 2D version. Depending on initial guess I got errors "requested matrix element does not exist". The situation seemed to improve a little by pre-allocating the vectors X and Y yet it didn't become really robust.
So instead of assigning to j+1 elements I used augment() to add new points to the iteration history.
This is the original version:
Newton2D.sm (21,4 KiB) scaricato 1564 volta(e).
And this is the modified version.
Newton2Da.sm (19,03 KiB) scaricato 1688 volta(e).
Wrote... can't find 2nd root
2nd root confirmed exact.
Solve(f,q,x0,x1,TOL) Copy.sm (162,62 KiB) scaricato 1685 volta(e).
Another way, keeping the mathematical formulation and the iteration algorithm separate. As here.
Newton2Da.sm (13,34 KiB) scaricato 1732 volta(e).
Thanks Alvaro, added to my next Samples visit.
Take care ... Jean
Take care ... Jean
WroteI cannot use the roots function and must use one old good simple method by Newton.
An old vintage in Smath ... two examples.
Take care Valery ... Jean.
Solve_roost f1(x,y). f2(x,y).sm (27,42 KiB) scaricato 1676 volta(e).
Two variations added.
Newton2Da. v2.sm (38,35 KiB) scaricato 1676 volta(e).
Newton2Da. v2.pdf (152,11 KiB) scaricato 1148 volta(e).
sergio 03/05/2023 14:29:00
WroteTwo variations added.
From my future article
Если уравнений не два, а три, то матрица Якоби будет состоять из трёх строк и трёх столбцов. При этом графически отображать решение придётся не двумя кривыми, а тремя поверхностями на 3D-графике, причём их взаимное пересечение и будет отмечать решение (задание читателю).
Слабо!
Alvaro 03/05/2023 03:21:00
You may find this Treasury useful/productive.
Solve(f,q,x0,x1,TOL) Copy.sm (300,16 KiB) scaricato 1708 volta(e).
