Custom Functions plugin
Custom Functions plugin - functions: extended Max and Min, Unit of Measurement, Order of Magnitude - Messaggi
#101 Pubblicato: 08/11/2017 20:04:30
Gruppo: Moderator
Thank you Alex, it's the same issue reported here, I'll try to fix it tomorrow
#102 Pubblicato: 09/11/2017 08:45:09
Gruppo: Moderator
Fix committed for the latest SS BETA; I'm aware there are still some drawing issues with cases due to something in SMath Studio itself.
#103 Pubblicato: 29/10/2019 07:50:37
Gruppo: Moderator
There is a problem with at() in build 7219:
It seems that the function at() isn't executed.
Materials E7-6.sm (10,32 KiB) scaricato 1599 volta(e).
Mostra spoiler
#104 Pubblicato: 29/10/2019 13:27:07
Gruppo: Moderator
Thank you Martin, I will look at it as soon as I can.
edit: fixed in later versions SS
#105 Pubblicato: 03/11/2019 09:18:28
Gruppo: Moderator
In the attached sheet, the conversion of solution results into definitions is demonstrated in two ways:
1. Usage of Assign(), a function made for this purpose in the Maxima plugin.
2. Usage of the substitution function at() from custom functions plugin, which by syntax should be good for the purpose.
It turns out that it makes a difference whether the Solve function is inside a line block or not. In the latter case, at() comes up with a strange error message.
Solve-3.sm (20,06 KiB) scaricato 1605 volta(e).
#106 Pubblicato: 16/05/2020 09:24:11
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.99.7251 Nightly Build and later
- Unknowns() improved to don't match integration variable of int(4);
Unknowns.sm (18,63 KiB) scaricato 1541 volta(e).
#107 Pubblicato: 06/03/2021 12:29:00
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.99.7691 Nightly Build and later
- [SS-4651] at() assignment improved to avoid unexpected substitutions when variables are given as replacements;
EDIT
either this should works correctly now:
sergio 06/03/2021 12:36:00, churichuro 06/03/2021 14:35:00
#108 Pubblicato: 24/03/2021 10:00:36
Jason McCool
Jason McCool
9 apprezzamenti in 78 post.
Davide, thanks for developing this plugin; I use several function in here regularly. One that I just tried using that could be very useful for me is the Ceil function. In engineering we often want to always round up, so this would fit that bill well. However, it seems to only round up with respect to the base unit instead of the unit actually used. So instead of rounding a result up to the next inch (or millimeter), it rounds to the next foot (or meter). Would it be possible to account for the unit in that evaluation somehow?
Thanks,
Jason
#109 Pubblicato: 24/03/2021 11:49:52
Gruppo: Moderator
Thanks,
Jason
Such a function would definitely need the target unit as input. In order to use this for display automatically, the plugin would need to suppress back-simplification to SI, which might require "Optimization None" on user side. A comprehensible operator form might put a placeholder for the unit at the index position to the lower left
ceil2.sm (3,77 KiB) scaricato 1617 volta(e).
#110 Pubblicato: 24/03/2021 12:12:26
Jason McCool
Jason McCool
Yes, that looks like it will do what I need. Good idea, Martin. Thanks!
And I like the idea of being able to define the output unit in the index position. That seems clear and streamlined as well.
#111 Pubblicato: 25/03/2021 09:56:13
Gruppo: Moderator
useful, consistant, I like it... agreed. I'll add it in the next plugin update.
Jason McCool 25/03/2021 09:58:00
#112 Pubblicato: 27/03/2021 12:42:00
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.99.7739 Nightly Build and later
  • added Ceil(2);
  • added Floor(2);
4 utenti hanno apprezzato questo post
sergio 27/03/2021 12:46:00, fedeghi 27/03/2021 13:51:00, NDTM Amarasekera 27/03/2021 23:50:00, Jason McCool 29/03/2021 09:30:00
#113 Pubblicato: 09/04/2021 10:42:14
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
Davide,
Since you are using a specialized output with the brackets and unit subscript, I would like to suggest ceil2 using a superscript for the unit. floor2 keeps the current subscript. Visually, this will help us "SEE" what was used in context to the equation/function
#114 Pubblicato: 14/04/2021 10:07:31
Gruppo: Moderator
Davide,
I get the point but seems to me that might be confusing when exponentiations are involved
Also, the "base" could be a variable, or a simple number
#115 Pubblicato: 19/05/2021 04:54:46
Martin_B
Martin_B
22 apprezzamenti in 84 post.
Hi!
The var2str from custom functions plugin has problems with the new release:
appVersion(4)="0.99.7808.230"
var2str(1.7,2)="1,70"
var2str(1.7,"0.00"="0002E02"
var2str(1.7,"0,00"="0002C02"
#116 Pubblicato: 19/05/2021 06:28:41
Gruppo: Moderator
Yes, this is related to changes in text encoding, I'll fix it ASAP.
#117 Pubblicato: 22/05/2021 12:38:20
Gruppo: Moderator
PLUGIN UPDATED SMath Studio 0.99.7808 and later
  • fixed encoding/decoding issues;
  • refactoring;
churichuro 22/05/2021 12:55:00, sergio 22/05/2021 14:54:00
#118 Pubblicato: 24/05/2021 11:40:10
127 apprezzamenti in 342 post.
Davide, I encountered this issue after the last update
Davide Carpi 24/05/2021 12:29:00
#119 Pubblicato: 24/05/2021 12:28:36
Gruppo: Moderator
Confirmed. I'll fix it ASAP.
#120 Pubblicato: 24/05/2021 12:30:02
What about if you specify Bolean completely ?
