Custom Functions plugin
Custom Functions plugin - functions: extended Max and Min, Unit of Measurement, Order of Magnitude - Messaggi
#21 Pubblicato: 10/02/2013 13:25:48
Gruppo: Moderator
I guess the problem is that in the example the variable V is not just a system but an expression involving systems. There was a sys2mat version with just replacing the "sys" in the string representation (num2str) by "mat". In the given case, this approach would fail.
Perhaps the function sys2mat should internally apply eval() and then do the replacement.
Martin
#22 Pubblicato: 11/02/2013 18:11:20
Gruppo: Moderator
PLUGIN UPDATED
- fixed issue of sys2mat() involving sys() special features (many thanks to [userlink]mkraska[/userlink])
best regards,
w3b5urf3r
Martin Kraska 12/02/2013 17:55:00
#23 Pubblicato: 17/02/2013 07:40:28
Gruppo: Moderator
The mat2sys function seems to be limited to column matrices. This might be a feature rather than a bug. In the first case I would recommend to be more specific in the doc string ("Converts column matrices (vectors) to systems" ). Alternatively, the linear indexing feature could be used to flatten the matrix.
Radovan Omorjan 17/02/2013 07:59:00
#24 Pubblicato: 17/02/2013 14:45:16
Gruppo: Moderator
Hi Martin
Yes, actually mat2sys function is limited to column matrices (the function brutally changes "sys(" to "mat(", without checks).
An improvement will be available ASAP.
best regards,
w3b5urf3r
Martin Kraska 18/02/2013 05:58:00
#25 Pubblicato: 20/02/2013 11:56:19
Gruppo: Moderator
PLUGIN UPDATED
- mat2sys() now can handle also non-column matrices (nested or not)
- sys2mat() symbolical enhancements
regards,
w3b5urf3r
sergio 21/02/2013 06:44:00
#26 Pubblicato: 15/03/2013 07:05:31
Gruppo: Moderator
PLUGIN UPDATED
  • added new texts functions:
    • strtolower(1): converts all characters in a string to lowercase;
    • strtoupper(1): converts all characters in a string to uppercase;
    • ucfirst(1): converts the first characters in a string to uppercase;
    • ucwords(1): converts the first characters of each word in a string to uppercase;
    all functions works both with texts or texts nested in arrays/systems;
  • added norme(): unofficial patch of SMath Studio norme() function (BUG shown here);
  • sys2mat(): fixed unexpected influence on input arguments.
Plugin's Sources are moved to the SVN repository (I have added a link in the first post)
regards,
w3b5urf3r
Martin Kraska 16/03/2013 15:24:00, sergio 15/03/2013 09:36:00, Radovan Omorjan 16/03/2013 03:19:00
#27 Pubblicato: 16/03/2013 15:59:58
Gruppo: Moderator
Hi Davide,
thanks for the update. I added the functions to the function reference in the handbook and also added a section on string functions.
The norme replacement is highly welcome. I just had a small problem, see attachment.
Just in case you are looking for distraction from real stuff like unit and systems proof solvers:
I'd vote for unit-proof versions of int(), Re() and Im() and arg().
Martin
#28 Pubblicato: 16/03/2013 16:17:55
Gruppo: Moderator
Thank you Martin;
the issue is related with some SMath bug involving transpose and the linear indexing feature ... Tomorrow I'll look in the bug section to see if it has already been reported and I'll update the plugin with your formula
#29 Pubblicato: 17/03/2013 07:40:20
Gruppo: Moderator
PLUGIN UPDATED
- fixed norme() issue involving transpose and the linear indexing feature;
- enhancements of ucwords(): now accept all Unicode white spaces as separator of words.
best regards,
w3b5urf3r
Martin Kraska 17/03/2013 19:50:00
#30 Pubblicato: 16/04/2013 09:58:33
sublim21
sublim21
3 apprezzamenti in 36 post.
Great job websurfer!
Would it be possible to change mat2sys such that it doesn't collapse nested matrices?
Please see attached
sys2mat_suggestion.sm (5,27 KiB) scaricato 1608 volta(e).
#31 Pubblicato: 16/04/2013 11:14:06
Gruppo: Moderator
Would it be possible to change sys2mat such that it doesn't collapse nested matrices?
That won't work as list nesting is not persistent:
[MATH lang=ENG]sys(sys(1,2,2,1),3,2,1)=sys(1,2,3,3,1)[/MATH]
mat2sys could, however, have an option to restrict the conversion to the outer level matrix and leave all entries as they are.
#32 Pubblicato: 16/04/2013 11:35:06
sublim21
sublim21
mkraska, you're right. sys2mat was a typo. Thanks!
#33 Pubblicato: 23/04/2013 04:31:11
Gruppo: Moderator
PLUGIN UPDATED
- fixed norme issue with 1x1 matrices
- UoM now get the units element-by-element from any matrix/system (nested or not)
best regards,
w3b5urf3r
#34 Pubblicato: 23/04/2013 10:54:12
Gruppo: Moderator
#35 Pubblicato: 04/06/2013 02:46:56
Gruppo: Moderator
A Nightly update for anyone are using SMath Studio 0.96.4902 (plugins -> online gallery)
- removed norme clone (not needed anymore)
- added not recursive [MATH eng]mat2sys.1(#)[/MATH]
- added not recursive [MATH eng]sys2mat.1(#)[/MATH]
best regards,
w3b5urf3r
customFunctions_examples.zip (4,11 KiB) scaricato 562 volta(e).
Radovan Omorjan 04/06/2013 03:05:00
#36 Pubblicato: 27/12/2013 09:29:52
Gruppo: Moderator
mat2sys requires the argument to be literal matrices. Matrix-valued expressions need to be evaluated first either by assigning them to a variable or by wrapping them in eval(). A similar issue has been reported for sys2mat and has been solved.
I propose to transfer the solution to mat2sys.
Davide Carpi 27/12/2013 20:24:00
#37 Pubblicato: 01/03/2014 12:12:08
Gruppo: Moderator
UPDATED
- new function: InterpBilinear()
- new function: GetType()
- mat2sys() improvements for 1x1 matrices
(examples attached in the first post)
2014-03-01 17_13_27-SMath Studio Desktop - [CustomFunctions_examples.sm_].png
ioan92 01/03/2014 15:59:00, Mike Kaganski 01/03/2014 18:23:00
#38 Pubblicato: 22/06/2014 18:42:25
Gruppo: Moderator
PLUGIN UPDATED
- added strsplit("string","delimiter" )
Best regards,
Davide
ioan92 23/06/2014 06:21:00
#39 Pubblicato: 23/06/2014 04:17:53
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Davide, try string.Join().
Davide Carpi 23/06/2014 04:57:00
#40 Pubblicato: 23/06/2014 05:37:48
Gruppo: Moderator
Thank you Viacheslav
Done: added strjoin(2)
Best regards,
Davide
ioan92 23/06/2014 06:20:00, Вячеслав Мезенцев 23/06/2014 05:40:00
