Transpose edit command?
Transpose edit command? - Messaggi
#1 Pubblicato: 27/02/2010 01:39:39
crun2
crun2
0 apprezzamenti in 10 post.
Is there an edit command to transpose a matrix/vector? Not a computed transpose but an edit.
eg I have
a={1,2,3}
I press the edit-transpose key and change the data to
.....{1}
a={2}
.....{3}
#2 Pubblicato: 27/02/2010 07:20:10
Gruppo: Moderator
Sorry, I did not quite understand the question.
Just a suggestion. Could you use [BB/] and [MATH] tag. Just copy from SMath and paste into it. If you like, you can also put the screenshots on the Wiki and make a link to those pictures by "Insert image" tag. It might be more understandable.
#3 Pubblicato: 27/02/2010 23:58:40
Greg Locock
Greg Locock
0 apprezzamenti in 53 post.
I don't think there is an edit command for transpose, but there is a transpose operator in the matrix toolbox
so after you've entered a, type a:a and then click the transpose operator (T)
