To find eigen vector and eigen values of matrix - eigen vector don not satisfy the orthogonality - Messaggi
The given a 5x5 matrix is
A=[ 0.1151 -8.571*10^{-18} 0.1638 -2.7427*10^{-17} 0.0546
-8.571*10^{-18} 0.3436 -3.2727*10^{-17} 0.2184 9.7954*10^{-18}
0.1638 -3.2727*10^{-17} 0.506 0 0.1638
-2.7427*10^{-17} 0.2184 0 0.6025 2.4242*10^{-17}
0.0546 9.7954*10^{-18} 0.1638 2.4242*10^{-17} 0.7639 ]
Using code as given in Introduction to the use of SMath Studio
Prepared by Gilberto E. Urroz, May 2010 in appendix 7 , the eigen values mat(0.0555,0.2192,0.4657,0.7266,0.8637) are correct which are compared with scilab and python but eigen vector is incorrect? All the eigen vectors do not obey orthogonality properties. How to got correct eigen vector?
WroteUsing code as given in Introduction to the use of SMath Studio
Prepared by Gilberto E. Urroz, May 2010in appendix 7 , the eigen values mat(0.0555,0.2192,0.4657,0.7266,0.8637) are correct which are compared with scilab and python but eigen vector is incorrect? All the eigen vectors do not obey orthogonality properties. How to got correct eigen vector?
It is important to remember that an eigenvector is not a unique thing.
For a given eigenvalue, there are infinitely many eigenvectors.
Glance through these 3 documents.
Maths eigenAll.sm (22,55 KiB) scaricato 1329 volta(e).
Maths eigenAll Companion.sm (63,72 KiB) scaricato 1357 volta(e).
Maths Polyroots_Eigen Copy.sm (128,98 KiB) scaricato 1310 volta(e).
WroteHow to got correct eigen vector?
Can you attach your worksheet? I will take a look, I've never used the cited program but it seems normal (via characteristic polynomial). Normally I would use Maxima for an eigenvalue problem in SS. That always worked for me, having done some comparisons (my expensive problems being coded in Matlab and Julia).
WroteWroteHow to got correct eigen vector?
Here I am attaching some portion of my the worksheet .
WroteWroteUsing code as given in Introduction to the use of SMath Studio
Your good suggestion my problems solved partially. eigen value and eigen vectors are correct but eigenvalues are not in sorted.
I have check if the matrix elements are all integers then the eigen values and hence eigenvector sorted. Here worksheet is attached.EiegenVectoreogenValues.sm (9,57 KiB) scaricato 1296 volta(e).
Wroteeigenvalues are not in sorted.
That is immaterial wrt the possible project suite(s).
Gilberto Urroz sorts same as Matcad.
dn_LinAlgEigenvalues(A) sorts differently, values are same.
As well dn_LinAlgEigenvectors(A) are differently sorted
with different arithmetic sign, but numerical values same.
All those codes create confusion.
Maths eigenAll.sm (39,2 KiB) scaricato 1304 volta(e).
