1 pagine (8 elementi)
Custom Function Plugin Error in SS 6520 - Messaggi
I am experiencing problem in installing CustomFunctions Plugin in SS 6520 (07/11/2017).
Even some items {(such as cases(), abs()}in the Function Index of Reference book have problems.
I am using Win 10 64 bit latest update.
Pl test the attached example.
Small Dams Flood Routing Ex-Program Method-Original-Simple3.sm (863,28 KiB) scaricato 1531 volta(e).
Confirmed as well,
NDTM Amarasekera 09/11/2017 23:47:00
Thank you, I'll fix it ASAP. As usual please be patient and keep reporting issues
WroteEven some items {(such as cases(), abs()}in the Function Index of Reference book have problems.
They might be related to the new rendering system. I miss the issues with abs() (not related to CustomFunctions, though), could you post a screenshoot? Thanks in advance.
Thanks David. Following Screenshots(SC) are taken before updating Custom Functions Plugin.
SC 1: Selected Function Index of Reference Book.
SC 2: abs() selected and before updating Custom Functions.
I will let you know the situation after updating Custom Functions.
File non trovato. File non trovato.
ndtma
ndtma
"The mind is everything. What you think you become."
Descartes said it otherwise: "je pense, donc je suis"
First intelligent expression since mankind !
This was said by Lord Buddha about 2600 years ago. I only quoted it.
Thanks.
Thanks.
Ah yes, there is a Conjugate() function in that worksheet
