How to get symbolic results from ODE?
How to get symbolic results from ODE? - Ordinary differential equation - Messaggi
#1 Pubblicato: 30/06/2024 20:25:33
netsonicyxf
netsonicyxf
2 apprezzamenti in 79 post.
#2 Pubblicato: 30/06/2024 21:32:27
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Symbolic results from ODE.sm (9,74 KiB) scaricato 1590 volta(e).
netsonicyxf 01/07/2024 08:47:00, sergio 15/07/2024 15:04:00, Valery Ochkov 30/06/2024 23:33:00
#3 Pubblicato: 30/06/2024 23:34:34
Valery Ochkov
Valery Ochkov
67 apprezzamenti in 713 post.
А у меня по-прежнему, если нет решения, то выдается старое решение, а не сообщение об ошибке!
#4 Pubblicato: 01/07/2024 01:32:31
Gruppo: Moderator
Завтра посмотрю можно ли это просто исправить.
#5 Pubblicato: 01/07/2024 10:44:31
netsonicyxf
netsonicyxf
Thank you. How do you input ",u(t)" in the brace?
#6 Pubblicato: 01/07/2024 13:06:09
Valery Ochkov
Valery Ochkov
I think so
dsolve( , u(t))
netsonicyxf 01/07/2024 21:44:00
#7 Pubblicato: 02/07/2024 22:34:21
Plugin less solution, with units, using the Wronskian and the variation of parameters method.
Symbolic results from ODE.sm (23,52 KiB) scaricato 1558 volta(e).
Davide Carpi 03/07/2024 23:46:00, netsonicyxf 06/07/2024 21:09:00, sergio 15/07/2024 15:16:00
