1 pagine (7 elementi)
Admittance [Bode plot] - Admittance [Bode plot] - Messaggi
The ZedGraph log did crash my Smath session.
Otherwise Bode data set is 1/1 MCD.
Project Admittance Copy.sm (47,46 KiB) scaricato 1424 volta(e).
WroteThe ZedGraph log did crash my Smath session.
Fixed for ZedGraph in attached. Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings.
Project Admittance Copy_alyles.sm (90,53 KiB) scaricato 1394 volta(e).
WroteFixed for ZedGraph in attached.Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings.
Thanks alyles, just doctored before your attachment.
I noticed ZedGraph does not support spline, unlike ordinary XY.
Project Admittance.sm (87,83 KiB) scaricato 1332 volta(e).
... [suite]
this Smath document has been doctored/finished for publishing.
Bode gain plot, phase plot ... both log plot X direction.
Project Admittance Copy.sm (150,21 KiB) scaricato 1338 volta(e).
... more general definition of phase:
Project Admittance Copy.sm (155,54 KiB) scaricato 1347 volta(e).
Figured out how to use Maxima's Draw2D(). This also looks nice for a logx plot. Plotted both Admittance and Phase in same graph. I like this as well because properties can be changed directly in SMath sheet.
I played around with XY Plot but was unable to find a way to use log axes.
Project Admittance Copy_Maxima_Draw2D_alyles.sm (183,41 KiB) scaricato 1464 volta(e).
Nice example!
I did a bit of cleanup, removed the markers and shifted some options to the settings dialog.
![2018-05-22 18_50_32-SMath Studio - [Project%20Admittance%20Copy_Maxima_Draw2D_alyles_Kr.sm_].png](/it-IT/files/Download/wLcyFy/2018-05-22-18_50_32-SMath-Studio---[Project%20Admittance%20Copy_Maxima_Draw2D_alyles_Kr.sm_].png)
Project%20Admittance%20Copy_Maxima_Draw2D_alyles_Kr.sm (97,31 KiB) scaricato 1594 volta(e).
4 utenti hanno apprezzato questo post
Davide Carpi 23/05/2018 06:09:00, frapuano 22/05/2018 18:26:00, Arie 22/05/2018 14:22:00, sergio 22/05/2018 15:00:00
