Why I am not getting output using Range
Why I am not getting output using Range - Messaggi
#1 Pubblicato: 24/09/2015 16:51:55
Basile
Basile
8 apprezzamenti in 172 post.
Why I am not getting output column?
Thank you,
Basile
#2 Pubblicato: 24/09/2015 20:16:24
Ernesto
Ernesto
13 apprezzamenti in 74 post.
You cannot divide by a vector. You must use a for loop. Also you must properly define a function with a different variable than the one you will use inside the function afterwards.
When I encounter issues in smath, I think it's best to put an equal sign after each step to show the result, it's easier to trace where the issues are.
#3 Pubblicato: 24/09/2015 22:00:05
Basile
Basile
Ernesto,
Thank you for the help but I am expecting the result to be a vector because I make a sweep.
Basile
#4 Pubblicato: 25/09/2015 00:56:26
Ernesto
Ernesto
My mistake. I think this is what you were looking for.
#5 Pubblicato: 25/09/2015 05:01:43
Basile
Basile
Yes,
Thank you,
Basile
