It's possible to block the negative input in field's?
It's possible to block the negative input in field's? - Messaggi
#1 Pubblicato: 12/09/2022 15:33:22
Hildebrando Pereira dos Santos Junior
2 apprezzamenti in 21 post.
Hey Guys,
It's possible to block the negative input in field's using smath viewer?
#2 Pubblicato: 14/09/2022 09:40:10
Gruppo: Moderator
Nope, the best way to accomplish it easily is to filter the output applying abs() to the value before using it.
a:1
a:abs(a)
f(a): ...
#3 Pubblicato: 14/09/2022 09:47:52
Thanks Davide! Actually i do this, i will use an formatted label to show some message warning the user
#4 Pubblicato: 14/09/2022 10:51:57
Gruppo: Moderator
You are welcome. As alternative one can develop a region that translates into a TextBox control with mask/validation filters. It might be tricky depending on the filter but it is feasible.
#5 Pubblicato: 14/09/2022 11:04:57
Wow! It will be a great plugin! It can be extend the use of smath viewer in so many ways
#6 Pubblicato: 14/09/2022 15:53:11
It's possible to block the negative input in field's using smath viewer ?
Pretty simple to zap negative values:
1. transform negatives to '0'
2. strip vector from '0'
No need using Smath Viewer.
Random [rnd(n)] Filter.sm (10,03 KiB) scaricato 1046 volta(e).
Composite clean negatives.
Thanks Jean, but it's not the case.
I have an long application developed in Smath Studio using Smath Viewer, and some of my algorithms need's a positive input for bending moment's. For now showing a warning message, and using an absolute value work, it's not the more elegant solution, but work.
#7 Pubblicato: 14/09/2022 16:41:46
I have an long application developed in Smath Studio ... , and some of my algorithms need a positive input for bending moment's.
The very original document at the algorithms level might help.
Not my discipline, but curious.
Refreshed version of the previous Filter Negatives.
Jean.
Random [rnd(n)] Filter.sm (10,07 KiB) scaricato 1040 volta(e).
Sure! The document is here:
DIMIS_219.sm (838,58 KiB) scaricato 1258 volta(e).
The section is called "Flexão Composta" the value of Msd, for this algorithm need's to be positive.
#8 Pubblicato: 14/09/2022 16:44:08
Gruppo: Moderator
Get use to what he do, but never bow down or surrender.
He will try to hijack your topics with totally unrelated replies.
Just report his irrelevant posts, mods will take care it eventually.
