default units
default units - how to set default units - Messaggi
#1 Pubblicato: 06/04/2018 12:04:43
sarregouset
sarregouset
0 apprezzamenti in 6 post.
Hi, I am trying to set the default units to Imperial (as required by my work) by changing the Units.xml file. However SMath crashes when I try to open it with the edited file in place. Can someone help identify my problem? My Units.xml file follows:
Mostra spoiler
mod: code too long, moved under spoiler; code tags added.
#2 Pubblicato: 06/04/2018 12:24:36
Gruppo: Moderator
#3 Pubblicato: 06/04/2018 12:32:24
sarregouset
sarregouset
Thanks; that's better than nothing. It would still be nice to know how to set default units (in vs ft) via Units.xml if there is no other way.
#4 Pubblicato: 09/04/2018 10:46:23
sarregouset
sarregouset
Scratch that; it's worse than nothing. The OutputUnitsSystem=Imperial setting seems to break the unit-display override feature. With it set, I can no longer specify which derived unit I want the results displayed in - I have to use the default. For example:
a:=1lbf
b:=1ft
a/b^2=1lbf/ft^2
a/b^2=70.7262lbf/ft^2inHg*psf
#5 Pubblicato: 09/04/2018 12:29:49
sarregouset
sarregouset
The point is, if I use the setting Davide suggested (OutputUnitsSystem=Imperial), I canNOT "append the result with the appropriate unit", whereas with the =Metric setting I can. In other words, this Smath feature does not work. Thanks anyway.
#6 Pubblicato: 09/04/2018 13:32:01
Gruppo: Moderator
Yes, it is a known bug (SS-2286); as you can see from the post I've linked above, it should be considered an experimental feature (this is enforced by the fact that you have to edit the settings file to enable it).
Loalized default units are part of [SS-1], still opened.
I do not encourage to modify the unts.xml file except for hardcore users on portable executables, since the file it is overwritten on software installations and not linked within the worksheets, that it means you cannot read a worksheet as it was created unless you have the same units file.
#7 Pubblicato: 09/04/2018 13:51:47
sarregouset
sarregouset
Thanks for those details. I noticed it was overwritten but did not it was not linked within worksheets. Looks like I am stuck with Metric unless something happens on [SS-1]. Thanks for your time.
#8 Pubblicato: 22/08/2022 19:30:59
⚜ Kenny Lemens, P.E. ᵂᴵ
85 apprezzamenti in 181 post.
Greetings,
If you are using (OutputUnitsSystem=Imperial); then there is a quick way to force 'inches' as the default unit.
- 1) Edit the Units.xml file
- 2) Locate the 'inches' factor
- 3) Edit the name: name="in" to name="ⅰn in"
- 4) Save & Close Units.xml
When you reopen Smath, you should note [ⅰn] as the preferred unit.
This works because [ⅰ] is a special character; it looks like an [i], but it sorts before [f]; thus it is your first to display.
      <!-- used [ⅰ] to sort in in front of other Imperial units (KML) 2022-08-19 -->
      <add factor="2.54" exp="-2" system="Imperial" id="309">
        <synonym name="ⅰn in" lang:rus="дюйм" lang:dan="tommer in" />
      </add>
A bit late, but I hope this helps the next person,
-Kenny Lemens, P.E.
#9 Pubblicato: 23/08/2022 09:58:56
sarregouset
sarregouset
Thanks, but that doesn't help due to bug SS-2286 described above.
#10 Pubblicato: 23/08/2022 10:16:19
Greetings,
I am still exploring the issues outlined in [SS-2286]; currently my fixes are:
-̶ ̶C̶r̶e̶a̶t̶e̶ ̶a̶n̶ ̶i̶m̶p̶e̶r̶i̶al̶ ̶u̶n̶i̶t̶ ̶f̶o̶r̶ ̶̶̶a̶c̶c̶e̶l̶e̶r̶a̶t̶i̶o̶n̶
-̶ ̶S̶u̶p̶p̶r̶e̶s̶s̶ ̶u̶n̶s̶u̶p̶p̶o̶r̶t̶e̶d̶ ̶u̶n̶i̶t̶s̶ ̶(̶e̶.̶g̶.̶,̶ ̶%̶ ̶̶a̶n̶d̶ ̶̶d̶e̶g̶r̶e̶̶e̶s̶)
- Redefine some constants in terms of imperial units ( i.e., g=32.2 ft/s² )
- Redefine some units in terms of imperial base units ( e.g., kip=1000lbf )
Far from a solution, but progress none-the-less.
I am currently trying to find a way to declare "Default Units" for system=Metric, but I haven't made much progress in that regard.
[EDIT] It is possible to edit the Units.xml file, so that the 'base units' are in terms of your desired 'default units'. An example to such a document is referenced in this post: https://en.smath.com/forum/yaf_postsm79741_Usable-default-units-for-US.aspx#post79741. There are a lot of rules to construct the Units.xml file correctly; no good way of summarizing the method to assign a custom unit as default.
-Kenny Lemens, P.E.
Keegan Imig 17/10/2025 11:58:45
#11 Pubblicato: 17/10/2025 11:57:37
Keegan Imig
Keegan Imig
0 apprezzamenti in 4 post.
@Kenny, did you ever determine a solution for this issue?
-Keegan
#12 Pubblicato: 01/12/2025 17:09:46
Greetings Keegan,
Yes; I have had success in modifying that units.xml file; but it is very customized to my preferences and works in tandem to a plugin I created to handle aliases and the such; making it hard to just share it as a standalone item.
I see you are intrigued by this; what units would you want as 'defaults'?
May this be of Good Help;
