1 pagine (15 elementi)
Plot Vector - Messaggi
Amazing application. However I have a question on vectors.
Can I plot vectors?
Like:
r(t):=[5;3]+t*[1;4]
A vector with the increase of a=4, starting at 5;3.
Right now I have to rewrite it manually to a y-function. Not practical for math classes :P
Happy user elsewise
Mike
Can I plot vectors?
Like:
r(t):=[5;3]+t*[1;4]
Happy user elsewise
Mike
Hello Mike,
Could you be more specific, please. I do not quite understand your question.
P.S. Maybe something like this?
Looks ugly :P
But I think I get the idea, still. It requires me to manually split my vector.
You know, that a vector is a collection of x, y, z functions represented by a variable, t.
So:
There, I would like to write f(x) in the plot.
Where after the plot will generate an amount of points.
What you do, is generate the y-coordinates, then enter it into the plot with the x-coordinates.
So:
Hello Mike,
Maybe this might help. If I was wrong, just let me know.
Function can return matrices or vectors (column matrix).
In general, what you're trying to do, is script your way out of it :P
It's not gonna work everytime, if I have to script my way out of it (Lazyness :P).
Although, it's a feature I'd like to see implemented.
Btw. The way you specify x(t), y(t), z(t), is not the way to put them into a vecotr in my learning.
f(t) = [1;2] + t * [3;4]
Becomes:
x(t) = 1 + t * 3
y(t) = 2 + t * 4
Ofc. it completely depends on how you set up the assignment / decide to solve the task :P
Becomes:
x(t) = 1 + t * 3
y(t) = 2 + t * 4
Hello Mike,
Sorry if I am to persistant. Just trying to figure out your problem (sorry if I am also to slow
) and to practice SMath
. Is this of any use to you?
Some complicated scripts with functions are not possible at the moment, but SMath has some features I did not discover yet.
Wow. It's getting closer (Not sarcastic).
But yes. That's basically what I'm trying to acomplish here.
To put the X / Y into the coordinate system, one would just augment them?
EDIT:
How do you make the superseded 1 and 2?.. To make X and Y?
EDIT:
Hello Mike,
Here is another try.
I do not know any other way in this case, maybe someone else does.
I hope I understood the question. If not, sorry.
Just press X[1 and you will have vector X with index 1:
WroteWow. It's getting closer (Not sarcastic).But yes. That's basically what I'm trying to acomplish here.
WroteTo put the X / Y into the coordinate system, one would just augment them?
WroteEDIT:
WroteI hope I understood the question. If not, sorry.
I can't make it happen... Perhaps it's linked to the problem me and another Dane has making brackets... :/
WroteWroteI hope I understood the question. If not, sorry.
Yes, I read your posts about brackets and can not be of any help about it. I hope at leats you can choose "el" from the "Functions" menu or getting the same by typing el(X,1
Ok, so I tried with "el". Works.
However, I've found where my problem lies...
Everytime you make a graph... You use a range / programatics...
Everytime I make a graph (Not in SMath, real life), those are taken for granted.
I don't say that, for t = 0 to 10. That's not needed, all that is done behind scenes.
On the left side is how I'd like it not to look, and the right is the most optimal.
EDIT:
Plot needs to understand, that a matrix is ALSO interpretable as a set of coordinates.
EDIT:
Hello Mike,
In Mathcad you can do parametric plots without defining the range of variable or parameter (Quick plots)
But in SMath the parametric plots can not be defined this way (I wish I was wrong). You must define a range of parameter variable and make a two column matrix, and finaly plot that matrix
The only way of 2D plots, at the moment, without defining the scope of independent variable is to use it and name it as "x", directly or defining a function but in the 2D plot placeholders there must be a variable named x
or something like this (maybe someone would like this
Maybe in some next SMath release the parametric plots would be implemented.
I see.. So what I'm actually out for, is called "Parametric Plots"...
Interesting...
Smath... Get to it :P
Gimme' parametric plots... :P
Interesting...
Here and there the parametric plots are mentioned on this Forum. SMath officialy does not support parametric plots yet. Here is another possible implementation of them.
circles.sm
I have to mention that the multiline function, like in this example, are not officially suported by SMath as well. However, It is working in this case
. It is not advisable to use the multiline functions at this time because it is not quite clear how do they actually work and unpredictible sidefects can arise.
P.S. Andrey, It seems that F8 and changing variable names at once in Equation system for graphs does not work. Should it be that way?
circles.sm
Andrey Ivashov 06/08/2010 20:16:00
WroteIt seems that F8 and changing variable names at once in Equation system for graphs does not work. Should it be that way?
Yes. F8 and DA don't work inside Plot regions. Will implement this later.
Regards.
