Sum function error
Sum function error - Messaggi
#1 Pubblicato: 10/04/2020 19:30:22
Andrey007
Andrey007
0 apprezzamenti in 7 post.
Hi, I ask you to help with the implementation of the calculation of the sum of the series for ranked variables, since this was done in the MathCAD program. I enclose the codes of the programs MathCAD and SMath. It would be nice if they produced the same result, though I don’t really understand how to implement this in SMath. Please correct my code if there are errors.
thanks
File non trovato.File non trovato.File non trovato.
#2 Pubblicato: 10/04/2020 20:44:18
churichuro
churichuro
29 apprezzamenti in 79 post.
#3 Pubblicato: 10/04/2020 22:30:38
Hi, I ask you to help with the implementation of the calculation of the sum of the series for ranked variables, since this was done in the MathCAD program. I enclose the codes of the programs MathCAD and SMath. It would be nice if they produced the same result, though I don't really understand how to implement this in SMath. Please correct my code if there are errors.
Smath does not have the range summation Mathcad style.
The code is as per doctored by Davide.
You may have to watch the divide by zero.
Better use Smath Floor from main f(x) menu.
Takes long times to plot Eqef(j)...
Programma 1.sm (16,3 KiB) scaricato 1171 volta(e).
