UPDATED: SMath Studio 0.98.6356 (27 May 2017) - Messaggi
Offre numerose funzionalità di calcolo e un'interfaccia utente ricca, tradotta in circa 40 lingue diverse. L'applicazione include inoltre un prontuario matematico integrato.
L'applicazione può essere facilmente estesa in base alle proprie esigenze. Lo strumento integrato "Gestione estensioni" consente di accedere a centinaia di risorse, sia ufficiali che di terze parti, tra cui: esempi d'uso, plug-in, applicazioni basate su SMath Viewer, frammenti di codice, traduzioni dell'interfaccia, libri interattivi, manuali e tutorial.
Download
SMathStudioDesktop.0_98_6356.Mono.tar.gz (1,25 MiB) scaricato 2707 volta(e).
SMathStudioDesktop.0_98_6356.Setup.msi (2,12 MiB) scaricato 5882 volta(e).
The only visible change to the build released yesterday is:
- Usage of Descriptions for MathRegion (and other regions which contains MathRegion) are fixed - previously any input was duplicated between region equation and description.
Best regards, Andrey Ivashov.
In my megabyte heavy smath worksheets I was faced with very long recalculation times for the new build. I have "time stamped" the worksheet an realised that major chunk of reclaulation time is spent before any calcs are done in the worksheet.
This behavior is repeatable over many worksheets.
I will gladly share the worksheet privately via email.
Thanks!
WroteI will gladly share the worksheet privately via email.
Please send a worksheet to me, so I could test and fix this issue.
Thanks in advance!
