Opening a .xmcd file in SMath Studio
Opening a .xmcd file in SMath Studio - Error message - Messaggi
#1 Pubblicato: 30/07/2015 06:40:42
SteveG021
SteveG021
0 apprezzamenti in 2 post.
Morning,
I get an error message wehen opening a Mathcad .xmcd file in SMath Studio.
I have Mathcad V14 and SMath Studio V0.97 (built:5346).
I have attached an image of the error message.
Some of the file is converted propoerly but i have an issue with the IF functions.
I have attached the mathcad file which i need converted as well.
Thanks
Steve
API RP2A-WSD - SMath.sm (72,21 KiB) scaricato 1372 volta(e).
#2 Pubblicato: 30/07/2015 21:07:31
Ernesto
Ernesto
13 apprezzamenti in 74 post.
Wasn't this addressed in your last post (http://en.smath.info/forum/yaf_postst4702_If-statements.aspx#post23827) ??
The problem was in your "max" function in section 1.8. "max" function needs to have the arguments inside a matrix, to have it in the format you have (arguments separated by a comma) you have to use the "Max" function. Capital and lowercase makes a difference.
You have several "min" functions with the same issue (Section 1.5 and 1.6), where it needs to be changed to "Min".
