1 pagine (10 elementi)
Problems with animation - I can't get animation to work. - Messaggi
When I right click on the graph and try to animate, I get "t not defined."
test.sm (3 KiB) scaricato 1511 volta(e).
WroteWhen I try to animate, I get "t not defined."
SS 6179 is more convivial:
"plot then define animation variable"
Click over the plot then set the animation, variable.
I right click on the graph and then select animate t.
I select 2 frames per second.
Still get error, t not defined.
Make a PDF to enable re-coding.
Not a 10 pages PDF !
0Anim Butterfly in_situ Command Line FORUM.sm (13,71 KiB) scaricato 1372 volta(e).
Hi Lee. This is an example about how to animate a path in the plane. What kind of animation do you want to get?
Animating a path.sm (16,09 KiB) scaricato 1430 volta(e).
Mark R Harris 14/07/2023 21:36:00
I really appreciate your efforts!
I'm in the shallow part of the learning curve right now.
Anyway, here is my latest effort. Hope you can follow what
I'm trying to do.
Reviewing some of my old EE college math for fun and to gain
a way better understanding of complex sinusoids. The subject
matter was presented as water from a fire hose at the time.
I follow 3brown1blue and he had some interesting thoughts and
graphics on e^jx presentations. He also mentioned e^ix
kinda misrepresents what really should be exp(ix).
check out;
Attempting to generate the animate the graph as apha varies
in small increments as in the above youtube video at 2 minutes in.
Here is what I have so far;
Eulers Eqation 4 7-13-23.sm (10,81 KiB) scaricato 1373 volta(e).
I'm trying to do.
check out;
Native circle is from complex construction.
These 4 where constructed from Smath Studio.
Since Smath Studio does NOT exist anymore,
replaced by the poor infant Smath Solver,
NOT all Studio can be made live Solver.
Studio X_Y plot is generally not compatible Solver.
Complex_1 fails to plot, unless on new sheet.
Once the two vectors in hand, animate.
At this point, all that is baby stuff !
Advanced maths don't speak from formulation.
Animated Laplace Diffusion, Euler Advection
are two examples ... Once animated !!!
Circle Complexn-circles.sm (10,55 KiB) scaricato 1406 volta(e).
Circle Complex.sm (34,26 KiB) scaricato 1433 volta(e).
Circle Complex_1.sm (75,53 KiB) scaricato 1359 volta(e).
Circle Concentric OPTIONAL RADIAL Grid COPLANAR.sm (86,22 KiB) scaricato 1446 volta(e).
Please, let me know if 0K in your Smath Solver
