Reservoir Flood Capacity Estimation
Reservoir Flood Capacity Estimation - Basic approach to calculate capacity of a reservoir to absorb a given flood - Messaggi
#1 Pubblicato: 29/12/2015 07:16:29
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
The attached file shows basic steps involved in estimating the capacity of a proposed reservoir to absorb a flood of a given return period.
The required data are (a) Inflow Hydrograph and (b) Elevation/Area (Topography of the reservoir site).
The reservoir has a bottom outlet which can release a maximum of 200 cumec to prevent inundation of a nearby town area downstream of the proposed reservoir.
This is based on a project study undertaken in Sri Lanka.Reservoir Flood Capacity Estimation.sm (188,6 KiB) scaricato 1658 volta(e).
Radovan Omorjan 29/12/2015 10:23:00, Davide Carpi 29/12/2015 13:03:00, overlord 08/04/2016 08:20:00
#2 Pubblicato: 29/12/2015 10:28:02
Gruppo: Moderator
Very impressive, thank you
Just a small typo after the definition of function CtoE(x,X), I think. The call is CtoL(x,CC) (L instead of E)
#3 Pubblicato: 29/12/2015 11:16:37
NDTM Amarasekera
NDTM Amarasekera
Thank you.
#4 Pubblicato: 29/12/2015 23:22:13
NDTM Amarasekera
NDTM Amarasekera
Many thanks to omorr for pointing out the typo in call to CtoL(x,CC), next to the definition of the function CtoE(x,X).
It should be corrected as CtoE(x,CC).The result will be CtoE(x,CC)=60m, where CC has been defined as 150 MCM.
Sorry for the inconvenience.
#5 Pubblicato: 08/04/2016 08:21:25
Gruppo: Moderator
integral isn't calculated in this example. Culprit is maxima plugin. If it is installed you can't get a result.
#6 Pubblicato: 08/04/2016 08:43:08
NDTM Amarasekera
NDTM Amarasekera
http://en.smath.info/forum/yaf_postst7429_Definite-Integration-of-the-Exponential-Function.aspx
Thanks. This has been discussed.
#7 Pubblicato: 08/04/2016 14:48:36
Integral works for me:
You are totalising an hourly rate of accumulation
over the [a,b] time limits for a total MCM [m^3]
