Sqrt Problems
Sqrt Problems - messge says cannot calculate - Messaggi
#1 Pubblicato: 09/12/2019 14:36:21
Kelvin Edge
Kelvin Edge
0 apprezzamenti in 1 post.
Hi, I'm a new user of smath and have come across an issue when I try to calculate the sqrt for a range of values, I just get a message saying that smath is unable to calculate. Attached is an image of a simple sheet showing what I am trying to achieve, ideally I wouldn't have interim values for f listed root problem.PNG
Any help gratefully received.
#2 Pubblicato: 09/12/2019 15:19:46
127 apprezzamenti in 342 post.
If you want to use a function (in this case "sqrt" ) for each of the vector elements, you must use the SpecialFunction "vectorize". another possibility is to run a "for" loop.
#3 Pubblicato: 09/12/2019 21:24:11
Simply like this.
