How to obtain the Peak of this example?
How to obtain the Peak of this example? - Messaggi
#1 Pubblicato: 25/02/2023 04:14:28
liwenbus
liwenbus
0 apprezzamenti in 7 post.
Hi, guys:
Here is a formula
And the Targets are:
1. Draw the plot, but only the first quadrant is required.
2. Find the value of fn when M is maximum.
3. Find the maximum value of M.
I did the 1st target successfully, but can not find the values of fn and M. I have tried my best and search the forum but could not find any way to fix it. Please help to fix it, Thank you very much!
LLC.sm (12,37 KiB) scaricato 1326 volta(e).
#2 Pubblicato: 25/02/2023 09:57:08
liwenbus
liwenbus
You need the Golden ratio ... doctored version.
If the function is a data set, spline/smooth the region
... as well the FindIndex is a good utility.
LLC Doctored for MAX.sm (27,88 KiB) scaricato 1277 volta(e).
Golden ratio QUICK Copy.sm (123,8 KiB) scaricato 1314 volta(e).
wow!I think I understand, it is very useful, thank you very much!
#3 Pubblicato: 25/02/2023 14:41:41
Gruppo: Moderator
The built-in functions are perfectly well suited for the purpose. You just need to separate differentiation from root finding.
LLC.sm (11,01 KiB) scaricato 1303 volta(e).
sergio 25/02/2023 16:40:00, João Felipe Seráfico Melo 26/02/2023 06:38:00
#4 Pubblicato: 25/02/2023 20:54:24
... refreshed version.
Golden Search Copy.sm (23,62 KiB) scaricato 991 volta(e).
#5 Pubblicato: 26/02/2023 20:58:40
Gruppo: Moderator
Here is your functions peak point solved with various solvers.
LLC1.sm (9,33 KiB) scaricato 1319 volta(e).
#6 Pubblicato: 27/02/2023 22:55:02
It all depend upon the accuracy you want.
Smath was not even ½ pregnant that roots existed from libraries.
#7 Pubblicato: 27/02/2023 23:13:37
Gruppo: Moderator
Apart from Findroot() there are other functions in Nonlinear Solvers to.
Check that plugins page in Reference Book, there may some info you can use.
LLC1.sm (13,8 KiB) scaricato 1334 volta(e).
