Gamma(x ... Read More
Gamma(x ... Read More - Gamma(x) ... Read More - Messaggi
#1 Pubblicato: 12/06/2017 09:24:29
Can't explain:
1. γ(a,x) does Not plot on canvas [whatever 'a']
2. Γ(a,x) integrator => strictly upper limit 100
3. "t not defined" ... Smath does not interpret ?
4. Does not solve either !
_____________________________
Worth visiting this document [ < 10 sec]
Designers: can you upgrade/repair to "Casio"
Don't miss the Casio link in the document.
Could it be the Smath Simpson Integrator is the guilty One ?
Maths Gamma(x) Incomplete.sm (46,42 KiB) scaricato 1381 volta(e).
#2 Pubblicato: 12/06/2017 10:01:52
... forgot this:
For the discrete quick plots [γax,Γax]: options/Integral accuracy 100.
Then, disable the two discrete modules & quick plot.
For accurate work sheet calculations: Options/Integral accuracy 10000
Cheers .. Jean
#3 Pubblicato: 12/06/2017 13:35:54
Gruppo: Moderator
The problem seems in t^{a-1}; if a is less than 1, this term is 1/nthroot(t,...), therefore is infinite in 0 -> you can fix it using 10^-15 as lower bound of the integration (in such cases).
