Prode Properties
Prode Properties - Permits to calculate the properties of a pure fluid or a mixture - Messaggi
#21 Pubblicato: 08/06/2020 04:45:06
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Updated.
Changes:
- function descriptions fixed.
frapuano 08/06/2020 06:55:00
#22 Pubblicato: 09/06/2020 09:37:09
Gruppo: Moderator
Updated.
Changes:
- some functions added:
  • mc_HVF(5) - [ stream, h, v, et, ep ] solves the flash operation
  • mc_SVF(5) - [ stream, s, v, et, ep ] solves the flash operation
  • mc_setValidPhase(2) - [ stream, phase ] sets the phase compostion as valid
They appear only if exported by the library.
#23 Pubblicato: 19/06/2020 04:19:41
Gruppo: Moderator
Updated.
Changes:
- fixed error when freeing resources;
- small improvements.
frapuano 19/06/2020 09:36:00
#24 Pubblicato: 18/11/2021 19:37:24
Gruppo: Moderator
SMath Studio compatibility
Very strange, but I found that the plugin is broken for the 32-bit version. A small change restored it to work (225 functions loaded). Plugin updated.
Changes:
- fixed an issue when working in 32-bit mode.
