Probability Programs
Probability Programs - Probability Programs Conversion from MC15 - Messaggi
#1 Pubblicato: 28/12/2022 23:00:30
Norm Schutzkus
Norm Schutzkus
9 apprezzamenti in 90 post.
Hello SMATH Collaboratory. I attempt to convert an older MC15 worksheet, yet stumble on my poor programming skills. Attached please find my attempt in SMATH and the MC15 worksheet.
I welcome your recommendation(s) to get my SMATH worksheet program "P" working and I'll attempt to take it from there to finish the conversion.
Sincerely,
NormFile non trovato.File non trovato.
#2 Pubblicato: 29/12/2022 03:28:10
Hi Norm. SMath can't assign a column like Mathcad column operator, but you can emulate it with a range.
BTW, I don't have Mathcad 15 at home, and can't read your Mathcad file. Hope that this helps
#3 Pubblicato: 29/12/2022 11:35:11
Norm Schutzkus
Norm Schutzkus
Happy Holidays Alvaro!
Thank you, for your recommendations. I updated my worksheet, but the "Requested matrix does not exist". I added a snip of the "P" matrix expected from the MC sheet. The updated SMATH worksheet is attached.
I printed the MC worksheet to pdf but it expands the page width, thus there are multiple cut-off pages.
Again, I welcome your review recommendation(s).
Sincerely,
Norm
Alvaro 29/12/2022 15:09:00
#4 Pubblicato: 29/12/2022 11:42:27
Gruppo: Moderator
I didn't revise all your functions.
Only P, but it results same as in mathcad.
Rest is up to you.
Probability Programs_overlord.sm (51,45 KiB) scaricato 1310 volta(e).
#5 Pubblicato: 29/12/2022 12:42:54
Norm Schutzkus
Norm Schutzkus
Happy Holidays and many thanks!
I'll press on using your recommendations. I would have never gotten this far; given up without this forum's help.
Sincerely,
Norm
#6 Pubblicato: 29/12/2022 15:09:11
Hi. Happy new year and thanks for the pdf. Here some full vectorized versions.
Probability Programs.sm (50,3 KiB) scaricato 1276 volta(e).
#7 Pubblicato: 29/12/2022 21:13:51
Norm Schutzkus
Norm Schutzkus
Ah-h! A bit closer thanks to Alvaro and Overlord!
My worksheet takes longer to calculate relative to MC15. Overlord's version worked well and I tried Alvaro's version for the "P" program to see if it calculated faster. The P2(n) program didn't work initially; I replace "i" with "P" in the first "for" command line, which worked, but may make the routine take longer.
Anyway, thanks again for your help.
Sincerely,
Norm
Probability Programs.sm (74,83 KiB) scaricato 1353 volta(e).
#8 Pubblicato: 29/12/2022 21:18:49
Norm Schutzkus
Norm Schutzkus
By the way, how do you post your screen snips in the Forum?
Thank you,
Norm
#9 Pubblicato: 29/12/2022 22:39:13
Gruppo: Moderator
Use attachment button, and select a picture file.
In your case, a screenshot file.
I have tried some variations for your function.
I found this to be fastest, actually 3 times faster than my previous.
I used an amalgam of Razonar's and my functions.
Probability Programs_overlord_v2.sm (37,25 KiB) scaricato 1343 volta(e).
#10 Pubblicato: 30/12/2022 11:46:03
Norm Schutzkus
Norm Schutzkus
Very nice!
Thank you!
Sincerely,
Norm
#11 Pubblicato: 30/12/2022 22:36:18
Norm Schutzkus
Norm Schutzkus
Just a follow up...
Both versions attached; the faster calculated version (V.1) posts some big percentages, e.g. T4 relative to T3. Don't know what significance that poses.
Are the "P" programs structured random number generators? It appears to me that the "time(1)" relative to "t0" provides how long the program took to complete it's routine. Those outputs are compared for probability percentage?
The last page in V.1, "fcompare()" fails. I welcome your recommendation(s); looking to create row 1 of the matrix.
Thanks in advance.
Norm
