API - Entry.Create() with unit
API - Entry.Create() with unit - Messaggi
#1 Pubblicato: 22/03/2017 11:51:14
gregi
gregi
1 apprezzamenti in 5 post.
I am beginning my yourney into SMath API. My current bigest problem is how to add a unit to custom function return value.
I am using IPluginLowLevelEvaluationFast interface and in my TryEvaluateExpression implementation I am returning some double value by: result = Entry.Create(TermsConverter.ToTerms(sampleDistance.ToString()));
It works ok, but the question is: how to add unit to result of TryEvaluateExpression, for example standard length measuer - meters ?
Can it be dony by Terms of result of function TermInfo?
Any help will be apreciated
#2 Pubblicato: 22/03/2017 12:33:09
csb531
csb531
0 apprezzamenti in 24 post.
Hello Gregi,
Could you please post your smath-file or at least a screenshot, so i can understand your question better?
Regards, csb
#3 Pubblicato: 22/03/2017 13:04:37
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
One possible way.
var expr = new List<Term>();
var val = new Term( "10", TermType.Operand, 0 );
var unit = new Term( "'m", TermType.Operand, 0 );
expr.Add( val );
expr.Add( unit );
expr.Add( new Term( "*", TermType.Operator, 2 ) );
gregi 22/03/2017 14:30:00
#4 Pubblicato: 22/03/2017 14:31:07
gregi
gregi
Thank you uni! Your solution is exactly what I needed
