1 pagine (4 elementi)
Hidden inputs are being printed - Hidden inputs are being printed to pdf file - Messaggi
I'm trying to print some calculations to PDF in a pseudo-table format by hiding the inputs. However when I try to print to PDF, the inputs are displayed and ruin the table.
The screenshots below are how it appears in SMath vs how it appears in the resulting PDF.
It only seems to be the case when a variable is defined; if the input is just a calculation then it will remain hidden.
Is there a way to prevent it from displaying the calculation input?
Thanks
Thanks
Modificato 06/11/2026 18:48:29
Please attach .sm file
WrotePlease attach .sm file
I've attached a file that shows the table in question, with some equations simplified to reduce the extraneous details.
When I plot this to pdf, it appears as shown in the screenshot above. Interestingly, if I copy this 'table' to a new file and plot it, the problem goes away. I have no idea what setting/parameter would cause that to happen though.
temp.sm (11,76 KiB) scaricato 53 volta(e).
Modificato 09/11/2026 14:48:52
So I copied my entire calc sheet to a new file and tried printing and it does indeed work without issue. I have no idea what is wrong with that original file, but the issue seems to be resolved for me unless I make the same 'mistake' again.
